Looking for a slip yoke elim. kit for 208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Corey-88K5, Apr 25, 2000.
  1. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I've been looking for a slip yoke elim. kit for the 208. Advance adapters doesn't even make one. What the helk is going on here?!?!?!
    Why can't these idiots get their poo poo together.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  2. walrus101
    walrus101 Registered Member
    Apr 9, 2000
    91
    texas
    sorry i can't help you, but if you find a place please post.
    walrus101
    goo goo gaju
  3. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Corey
    Check with Tom Woods at www.4xshafts.com. He sells both JB Conversions and Currie Enterprises slip yoke eliminator kits. Or you can contact the manufacturers directly. They have it for the NP241 so I would guess they would have one for the NP208.
    Good Luck
    Brian
    Still in search of the TBI KING!!
    P.S. The JB Conversion's 241 kit direct from JB is $340.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I don't know of anyone who makes a kit for the 208. Maybe you could find a 241 for a reasonable price and then convert it to fixed yoke.
    I think the only reason they have a kit for the 241 is that is basically uses the same parts as the kit for the 231 so there wasn't much R&D required to market the kit, and there probably isn't much of a market for a 208 kit since they are mostly found in fullsize trucks which don't run into the driveshaft angle problems as much as Jeeps and there are not as many people building them up for the trail.
  5. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Corey if you want the fixed yoke to keep fluid in your case when the driveshaft breaks then just carry a plug with you. I made one for my Suburban with the NP208. Noone makes a fixed yoke kit for the NP208. If you want a fixed yoke for driveshaft angle then you're better off swapping in a NP241, NP205 or Atlas. You could have a machine shop make up the parts using the slipyoke and welding a retaining collar on the back. You would also need a roller bearing for support.
    CB
  6. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I thought I read some where that Dodge's use (used) fixed yoke 208s. If so, it would be fairly easy to find a complete Dodge 208 case and swap in the output shaft and housing from the Dodge 208 to your Chevs. LEt us know if this works.
    ken
