looking for another weird part
Discussion in 'The Garage' started by towdriver80, Apr 25, 2005.
  1. towdriver80
    towdriver80 Registered Member
    Jan 16, 2005
    41
    Maybrook, New York
    Nothing normal ever breaks on my truck. On my th400 tranny, driver side, right before the t-case adapter, there is what looks like a freeze-plug. rusted out, and started pissing atf from the center. Anyone know if this is really just a freeze plug? If it is, what size and where I can get one? You guys are my last hope. The parts store guy just laughed. Thanks again! :grin:
  2. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    freeze plug. any tranny shop or just pop out and measure hole and go to auto shop like napa, carquest. and ask for that size plug. easy to fix.
  3. towdriver80
    Jan 16, 2005
    41
    Maybrook, New York
    Thank you! I was going to remove it, but wanted to be sure it was a freeze plug before i started beating on it. :grind:
  4. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    Tranny shop!
    It might be the cover for the Accumulator Piston he's looking for???or the govenor??(I dont recall any freeze plugs on any of my TH400's,but I never paid close attention either! :blush: )--a tranny shop will probably have it,regardless of what it is,if it is the accumulator piston cover,there is a strong spring under it,and you might need the special tool to remove and intall it..might not be easy to do at home in the driveway... :crazy:
  5. sweetk30
    Nov 1, 2004
    25,554
    547
    good call but as he said its 4x4 and driver side. in that thay had no speedo and put plug in the place of it. but make sure its that. and i would just go to tranny shop first.
  6. towdriver80
    Jan 16, 2005
    41
    Maybrook, New York
    There`s no way there`s any kind of spring tension on that thing, it would have blown out by now in it`s condition. I`m going to just beat it out on my next day off. Thanks guys!
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    uhm speedo is in tailshaft housing in which there would not be on 4x4 tranny this is why the speedos are in the TC's
    2wds run speedo, are in tailshaf housing, since 2wd use them and much longer output shaft
    good luck
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Well that and the fact that the speedo would read WAY high in low range if the reading came from the trans. :cool1:
