Looking for bolt together roll cage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kayak, Jun 10, 2000.
  1. kayak
    kayak Registered Member
    Apr 25, 2000
    33
    I'm looking for a source for a bolt together roll cage to protect the front seat area of my 1987 GMC Suburban (see attached Photo). Anyone know of any? Thanks
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I like the snorkal. Was that custom made?
    Brian
  3. kayak
    Apr 25, 2000
    33
    The Snorkel is made by Safari Snorkel (Australia). It was designed to fit an 80 Series Toyota. I ordered it through Land Cruiser Connection at http://www.landcruiserconnection.com/ (ask for Bill)
    It takes some alterations to the inside fender well. Works out pretty easy. The radiator expansion tank needs to be moved rearward about 3" inches.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  5. kayak
    Apr 25, 2000
    33
  6. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    Smittybuilt use to make an in cab bolt-in cage for 73-87 pick-up trucks, but discontinued. If you can find one. It will bolt in, but you will have to cut the rear mounts, and extend them by welding in about 6" and then re-attatch the bolt mount pad. I can not find one. If you find one you will have to modify a lot to fit your application. Have one made would be you best bet
  7. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    cool burban
    [​IMG]Go prepared
  8. kayak
    Apr 25, 2000
    33
    Thanks for the info.
