Looking for D44 hi-steer arms; already searched
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazinaire, Feb 4, 2003.
  1. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I did a search already and found a set that caught my eye: http://www.ottindustries.com/steering_arms_dana44.html I like the idea of the arms having the rise built into them instead of using spacers, but I noticed that the ends that the draglink/ tie rod will mount to are flat and most other arms (now) are tapered. Is this a big deal? Is there really a serious clearnce issue between the springs and draglink/ tie rod if I were to use a flat arm with no spacer or is that only when using zero rates? I will be using a bent draglink. I would like to do this as cheap as possible, but want to do it right the first time, $310 for the 2 arms seems a bit steep and flat arms are much cheaper. I have already looked at a few other companies arms, can anyone recommend any other hi-steer arms for d44/10 bolts? Your help is much appreciated /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Are D44 arms supposed to have an angle to them???
    The Dana 60s have the 10 degree inclination to them and thus have to have the arms milled 10 degrees the other way to compensate.
    I thought the D44s did not have an angle to them.
    -- Mike
  3. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Check my post in the 4sale forum /forums/images/graemlins/cool.gif
