Looking for detailed pics of pulling 14bolt FF hubs....
Discussion in 'The Garage' started by jjlaughner, May 19, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Got my 14bolt tore apart and i'm trying to figure out the hubs? They are similar to the front I know. Can I use my Front Hub Socket or do I need a different one for the rear?
    /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The socket for the rear diff is different than the front.
    There are two different hub nut setups as well.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Once the axle shaft is out, then it's just like pulling the front hubs/rotors. But just to be a PITA, GM changed the bearing nuts during the life of the 14-bolt FF. Both of mine take a spanner socket that is similar is design to the one used up front, except it has 6 points instead of 4. /forums/images/graemlins/frown.gif I've got a really cool socket that I bought off a Mac Tools truck many years ago that has both the large 6-pin (for the rear) and smaller 4-pin (for the front) in one socket. /forums/images/graemlins/thumb.gif But some of the 14 bolt FF's use large hex nuts for the bearings. /forums/images/graemlins/confused.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Well horseshit. /forums/images/graemlins/smirk.gif Its the 6 lug spanner looking nut. Any idea the price on one of those hub tools.
    Is there anyway to get them off without the hub socket?
    I might call AutoZero and see if they have a loaner one. /forums/images/graemlins/thinking.gif
    How many nuts are behind the one I can see in the end?
    What order do they go? Like outside to in, nut, washer, nut... Does any of then have the little pins like the front hubs?
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    You can also use a punch and hammer to loosen the nut, they usually arent very tight /forums/images/graemlins/thumb.gif
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Thats what I'm wanting to here /forums/images/graemlins/waytogo.gif /forums/images/graemlins/ignore.gif
    I was going to give a whirl before I bought the hub tool /forums/images/graemlins/whistling.gif
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Autozone does sell the tool, not sure if they rent it or not, but it's under $20. I got mine on ebay that fits my 60 front and 14 bolt for $7.99
  8. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I got mine at advanced for 12 buck I did the punch and hammer thing and fawked the nut up so had to get a new one if I were you I would just get the tool
  9. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I think the one I bought was a little over $20 and it's a combo D44 front/14 bolt FF rear.
    The order goes nut, washer, nut. And the washer doesn't have pins like the front, but rather tangs (if that's what you want to call them) that bend over and fit in little indents of the inner nut.
  10. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I've got that page bookmarked and didn't even think about checking it out
