Looking for Diamond Plating
Discussion in 'The Garage' started by dbuda, Jun 10, 2005.
  1. dbuda
    dbuda Registered Member
    Apr 9, 2005
    6
    Lansing, MI
    Does anyone know where i can puchase a few sheets of diamond plate to replace the side interior panels of my K5. Does anyone have any suggestions on this process ( dos and donts) or another material that worked for them? :confused:
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    err you got a steel shop by you anywhere?
    they have ones buy me... can buy slithers or entire sheets... :cool1:
    I just bought a small piece of stainless and BOY IS IT SHINY!!!! :grin:
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Go to a local sheet metal fabrication type shop , a comercial or industrial one , they will be more likely to have some.
    Personally I would use aluminum checker plate 1/8" (diamond plate) because it is light.
    You can measure your rough cut sizes and have them shear it to size and then use a jig saw or sawzall to cut contours , notches etc.
    Use a buffing disk or file to remove all sharp edges
    BTW I am a sheet metal worker by trade :thumb:
  5. diesel4me
    Jul 24, 2003
    17,540
    928
    Massachussetts
    try here maybe?
    I've seen it at Lowe's Home Centers ,but its very expensive for a small sheet about 2x4 feet--it was 75+ bucks!....I'd try a steel supply place or sheet metal shop as already suggested..but it might not be cheap anywhere,diamond plate steel and aluminum has always been rather costly,and harder to find than regular flat plate steel..
    I've seen all kinds of stuff used as interior panels in K5's....T-111 plywood,wood paneling,acoustical ceiling tile,plastic panels used for lights in suspended ceilings,wavy courragated steel or fiberglass roofing panels,carpeting,Knotty Pine boards,Masonite panels--one guy even had Pegboard in his truck for side panels!...your limited only by your imagination !.. :crazy:
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I did the same thing with my panels. After I got the diamond plate panels cut I sprayed the backside of them with bedliner to keep them from rattling and vibrating against the truck.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I've seen some good prices at Online Metals and I plan to get some diamondplate from them in the future. They will even cut it to size for you, nearly for free. They only have aluminum, I think.
  8. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    Onlinemetals does steel, stainless, aluminum , titanium and even some plastics i think
  9. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    last time i priced a 4x8 sheet it was well over 150 range. and look in the phone book in the steel supplyers section.
  10. shugninx
    shugninx Newbie
    Jun 9, 2005
    4
    anchorage,ak
    Try metalsdepot.com
