Looking for exhaust outlet ideas
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmy88, Mar 13, 2004.
  1. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Did a search and saw lots of turn downs under the truck, which in PA would be illegal for inspection. Right now I'm toying with going under the frame just in front of the bump stop, running outside the spring just under the wheel well and turning out the rear quarter panel.
    So what ingenious way have you guys done it?
    Forgot to say its for rock crawling, but needs to be legal.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Heres where my pipe comes out wheeled on it 3 times since the lift went on last month and does not get touched by anything moving near it. It is near flush with the body so the inspectors can slide the sniffer in. It was in this same spot (under spring though) prior to the shackle flip and still had no problems: [​IMG]
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    how about right infront of the rear wheels, at a 45* with a 45* tip so it is flush with the body?
