Looking for gearing recommendations...
Discussion in 'The Garage' started by FWP, Apr 8, 2004.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The other 38" thread got me thinking about my setup. Instead of hijacking the other post, I'll ask in this one.
    What gears would you recommend for my setup? I drive it on the highway...
    TBI 355, Built TH350/ 2000 stall converter, 203/205, 14BFF, 38.5/14.5/15 SX (actual height at 25 psi=37.5") on steel wheels. Truck weighs 6800 lbs.
    Let me hear what you have to say! TIA
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    with the auto i would PERSONALY run 4.56's
    if there was something for the 14 bolt between 4.10 and 4.56 i would run it.
    i have ridden in your rig and you have offroad gearing down. it also didn t lag to much from what i could tell with your trailer behind you.
    if it was MY rig, i would yank out that sludge box and put in a 465. oh, wait i DID that in my rig. i will be running 4.10/42's/465 doubler. engine for now will be 350, then one day 6.5LTD or a 454vortec
    the only proble i will have will be with highway driving. ill have two choices. rap the motor out in 2nd, or bog down a bit around 65MPH. the highest i think i would take my rig would be 70mph.
    i am contemplating looking at new gears as i will be able to since i will be buying a new carrier for the front anyway. im thinking about 4.56's thne i can get thick gears for my 14 bolt. it would cost a bit mroe than planned, but is doable.
    Grant
  3. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    I think you'd do well with 4.56's...
    Rene
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I was thinking the same thing /forums/images/graemlins/wink.gif
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Rene
    Ditto /forums/images/graemlins/waytogo.gif
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    my input is not needed.
  7. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    i do fine with 38's and 4.56's
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Let me borrow your new shoes and I will try them out on my 4.56's in D and let you know. /forums/images/graemlins/rotfl.gif
    I think 4.56's is the better bet then 4.10's. I know I spin 3K in D with 4.56's and 35" MTR's for 65 MPH. They are only really 33.5" so though.
    With an actual height of 37+" 4.56's would be a good gear. RPM calc say 2650 RPM at 65. I used to run that when I had 4.56's and 32's with my OD. I really liked my cruise power at that RPM. I was kinda pissed when my 35's took that away, but thankfully TPI has made up for some of that.
    4.56's /forums/images/graemlins/thumb.gif
    Harley
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    We can just swap axles if you want. You can have my 4.56's and I will take your 4.10's. I just redid my balljoints so if your kingpins are in good shape we will call it an even swap. I will even drive to Prescott and help you swap them. /forums/images/graemlins/histerical.gif
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    /forums/images/graemlins/histerical.gif good one harley, thanks /forums/images/graemlins/histerical.gif
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    [/ QUOTE ] oh c'mon zakk, you're input is always needed /forums/images/graemlins/rotfl.gif
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I find this to be most handy in cases like this. Just make sure you use actual tire diameter rather than stated...
    [Edit] For my opinion, based on what I (think I) know of you and where you will likely be going in the future... /forums/images/graemlins/wink.gif
    I would say go 5.13. Then if you want to go 39.5 IROKs or something you will be set, and until then, it will be nicely responsive without being completely out of hand at highway speeds. If you sure you’ll stay where you are in tire size, then I would probably agree with 4.56. But it also depends on the torque curve of your motor, tendency toward performance vs. mileage, ratio of freeway to highway to back roads, etc…
  13. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    5.13 How much longer is it really gong to be a DD?
    I wish I would have gone with 5.13's when mine was a DD. Now that it's a trail truck, I've got to spend another $300+ for the 5.13's.
    BIGJ
  14. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I say get 3.55 gears in the Cummins tow rig that you're gonna get./forums/images/graemlins/histerical.gif
    Leave your axles alone!...
    Need more gear off road?
    Do the WMS 3:1 in the 203.
    Need more pulling power on the hi-way?
    Get the diesel tow rig.
    Blazer's a little slow on the road w/ the heavy tires?
    So what!?.... you racing anybody?! or do something about it and build a BB../forums/images/graemlins/grin.gif
    ..... just my uncalibrated opinion....
    Marv
  15. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Since you have a slight stall I would say go for more gear . 5.13's are still do-able with that O.D. tire and no O.D. in your tranny. I say gear it to where it performs like it should off-road not just to where it does O.K. .
    JMHO , Tom
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
