looking for ideas (water proof box)
Discussion in 'The Garage' started by NEK5, Feb 11, 2007.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Hey, guys. I`m going to be doing the headlight relay mod next week, and thought of putting the relays and circuit breakers, in a little water proof box, that I could mount on the inner fender, behind the battery...I`m just looking for something simple..anyone have any suggestions?
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    tuper ware
  3. dyeager535
    26,982
    191
    Use waterproof/resistant relays and connectors. I like the larger oval ones GM was using in the late 80's. Super easy to find in wrecking yards.
    Mount them high. (like GM did) Behind a solid portion of the core support will keep them dry even if plowing a fair amount of water.
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Dorean. Are you suggesting using those, instead of a water proof box?
  5. dyeager535
    26,982
    191
    Yep.
    Only thing would be the circuit breakers, but I'd just use fuses and not worry about it. They work while submerged anyway, and the only reason you'd blow one is faulty wiring. Circuit breaker really won't do anything for you, carry a spare fuse or two and forget about it. (you DO carry spare fuses anyways, right?) At least you know when a fuse blows, unlike a circuit breaker, you know exactly whats going on. :)
    The circuit breakers I've seen you could easily silicone or grease the few openings they have to waterproof them if you still wanted to go that route.
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    :haha: :haha: :haha:
  7. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Check out the plastic waterproof switch boxes at the hardware store:D If you really wanna be fancy get a thin sheet of plexi and cut it to be used as a clear cover. If the seal is broken you can tell at a glance.
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    yep lol tuper ware!:D
  9. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
    Also, check at radioshack there are all sizes of "project boxes" maybe some with clear covers, and use RTV or silicone to seal it. If you are that concerned with water how did you make your connections? Butt splices, wire nuts, or twist and tape? IMO the best connection would be soldering the two wires smearing on some silicone, RTV over the solder joint and pulling heat shink over the connection and rtv, then cook it all together. So the rtv squirts out either side of the heat shrink.
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Well, this a rare occurence, but I don't agree at all Dorian.... having resetable breakers is far superior to fuses, hands down... Certainly easier to see a tripped breaker than a blown fuse..
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
  12. dyeager535
    26,982
    191
    I'm thinking of the "automotive" style breakers that reset themselves, like you see on the fuse panel.
    If you've got the style that more closely resembles "house" breakers, then yes, no problem seeing where your problem is.
    But I stand by the fact that with good wiring, you won't be tripping them, so the added expense, trouble, and hassle of using them in an application that they should NEVER get tripped in, seems pointless. Obviously the circuit needs protection, but some blade fuses or whatever inline would be plenty easy and require no waterproofing.
  13. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    sealed in a box??..
    I'd suspect relays would corrode if sealed in an airtight container,that would "sweat" and form condensation..nearly all vehicle makers simply screw them to the core support or firewall,with little or no protection,or fit them in the fuse box with a non airtight cover....
    I feel some airflow over them would help keep them dry,if anything,especially if warm air from the motor or radiator gets blown on them..unless you plan to sink your truck like a submarine,I doubt the relays would ever get wet enough to cause any problems..:crazy:
