Looking for non sagging front lift springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by roadhouse66, Apr 30, 2002.
  1. roadhouse66
    roadhouse66 Registered Member
    Dec 6, 2001
    24
    Sanford, MI
    Hey guys, getting ready to put a 4" lift on my 86 Burby. It's currently a 1/2ton, but swapping in 3/4tons at the time of the lift. I would like a 4" lift with 35" tires. Soon after the lift, I plan on installing a Winch/bumper combo...which wieghs around 200lbs.
    What is a good set of front 4" springs that wont become 2" springs with the wieght of the winch/bumper?
    Any help would be great.
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Superlift Heavy Duty's..
  3. roadhouse66
    Dec 6, 2001
    24
    Sanford, MI
    Aren't those stiff as heck? Or is that what I'll be stuck with if I want a winch/bumper combo?
  4. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    I have heard good things about procomp springs... but dont know how heavy duty they are. Summit sells them for like 96.00 each. And their shipping surcharge on them is only like 6.00. it is a good deal since they are heavy to ship.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,090
    489
    Grand Rapids area
    "What is a good set of front 4" springs that wont become 2" springs with the wieght of the winch/bumper?"
    A set of 6" springs?
    Not sagging under weight is the exact same thing as high spring rate. High spring rate=stiff ride.
    You can always get an inch back by adding a 1" zero rate or some longer shackles. Those things would be easy to take back out if you were removing the extra weight. As an example, I am putting in shackles soon with two upper holes. Then with the hardtop off, I can get an extra 3/4" in the front to level the truck and give more room for the rubber. This will change the pinion angle by less then 2 degrees, too.
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I put a 400lb bumper on my front end with the 4" Rancho front springs (non-HD) and it didn't sag at all. What it did do was make the front end ride better.
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    BDS suspension. The springs are pre-sprung so to speak, meaning that they have settled as much as they are ever going to. Plus they have an unlimited life time warranty. It doesn't matter how you break it or how many times you break it, it's replaced free. As soon as I can, I am putting a new 6" system on my blazer. I wish I would have gotten them in the first place.
