Looking for opinions on body sag (yes, another one!)
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Ressurection, Jan 26, 2002.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Fellow CK5'rs, sorry to beat a dead horse (tell the ASPCA that's figuratively speaking), but I have the door-sticking problem w/ top off, as well. I'm a couple 2-3 yrs away from a resto, so my Q is: is it feasible to clean up the rocker box area, weld in new ones, then later tear the rest apart? Or would I be doing too much backpaddling?
    Thx!
    "High compression engines take longer to start!"
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    If you dont mind doin the little bit of extra work, I dont see where it would hurt anything. If you dont do it or shim it with some washers or something under the body grommets you will have 2 -3 years of headaches dealin with the doors.
    nathan
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would try shimming it or putting in a cage. My rocker boxes are in perfect shape and I can't open my doors either when flexed.
    I was bumbed to hear that Burt4x4 has the same prob. and he has a cage...Oh well?
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
