looking for pics of dana 44 and dana 60!!!
Discussion in 'The Garage' started by Supreme70, Dec 8, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I want to see the difference of the dana 60 and the dana 44 front axles side by side if someone has them. Single pics would be all right to as long as i can see both axles. need to know what im looking for in a junk yard.
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    king pins and studs in the diff housing to hold the leafs on for a 60. ball joints and 4 u-bolts holding the leafs on. if you find one in a wrecking yard, tell me where at so i can go look there.
  3. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    dana 60 style cap for kingpin. this is first year style the rest are tin. notice no ball joints.
  4. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    dana 60 's have no ball joints at all???? I thought there was some years that did, well thats what i was told.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    the newer d60's have ball joints (ford,dodge)
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The Dana 60 steering arm (top pic) has 4 bolts holding it on. The Dana 44 steering arm is curved and attached with only 3 bolts. Also the D44 has balljoints as shown in the pic.
  7. divorced
    Jul 20, 2004
    5,115
    The dana 44 has a u-bolt around the differential housing (yellow rectangle), and the Dana 60 has two bolts that thread into the housing (red circles)
  8. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Yes, what he said. If it has a place for studs, it is a D60.
  9. sweetk30
    Nov 1, 2004
    25,554
    548
    90% correct. the dodges used 2 bolts on there axles with dana 44s . so look for the 4 bolt caps. and no balljoints.
  10. divorced
    Jul 20, 2004
    5,115
    I just figured we were talking about Chevy stuff? :confused:
    It's good that you mentioned it for if the axles are already pulled.
  11. PsychoticDeadGuy
    Jan 8, 2005
    753
    ya, i almost made the mistake on the dodge d44 garbage. i noticed the studs but not the ball joints until further inspection. dodge is so weird.
  12. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Also you can't use only the king pin caps if you are looking for drivers drop fronts for SAS. Ford used king pin D44s in some F100s in early-mid 70s. For drivers drop you kinda have to know your stuff or scrape the web for the cast 60 since both the 44 (some) and 60s used on fords had Ubolts and king pins.
