Looking for spring bolt measurements
Discussion in 'The Garage' started by norville, Dec 23, 2006.
  1. norville
    norville 1/2 ton status
    Dec 27, 2005
    268
    A stones throw from Pargon Mountaintop Pa
    Hey folks, If my 77 burb doesn't sell. I'll be looking to lift it asap to get my tires under it. So Does anybody know the correct length and thickness of the front spring bolts? Also how about the u-bolts for D44 3/4 ton. I'm hoping to cut down on the parts running. I'm doing a shackle flip for the rear.
    Thanks,
    anybody running bfg 35x12.50's 16.5 on stock 6.75" rims?? No good?
    bob
  2. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    9/16 on the diameter & i believe mine are 6" long. U-bolt length will depend on the thickness of your spring pack but are easy to shorten w/ an angle grinder and a cut-off wheel.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Every spring bolt i've ever seen on a GM truck was 3/8" diameter and the length will need to be determined by the thickness of your spring pack but most spring bolts are 12" long and you cut them to length. The head of the spring bolts does vary though but most are 9/16" heads with a 3/8" thread.
  4. norville
    Dec 27, 2005
    268
    thanks guy's
    The springs arent any thicker than my factory pack, I'm hoping to pick up the ubolts at pep-boys before I start. The bolts I guess I grade 8's from the hardware store. I've never had good luck trying to save the bolts , it's much faster to just cut them off with wheel.
    thanks
    bob
  5. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    I'm thinking bolts for the front bushings/spring eye. I'll leave this stuff to people that can read.
  6. norville
    Dec 27, 2005
    268
    Johnny, you were correct I was looking for both.
    bob
