looking for stazworks wheels
Discussion in 'The Garage' started by rancid, Oct 5, 2006.
  1. rancid
    rancid 1/2 ton status
    Apr 24, 2005
    105
    utah
    looking for these stazworks wheels.
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    In the time it took you to put up this post you woulda found em...:rolleyes:
    www.stazworks.com
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    their website sucks! no prices or anything
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Price List
    These prices are based on materials used to create the particular rim. If the size of rim you want fits into more than one catagory your desired back spacing will be the determining factor of which way you can go.
    On the wider rims there is some things I would recomend to assure strength, call me if you are interested, but I am certain they would look kick ass and be very light and strong.
    [SIZE=+1]15" Rims[/SIZE] - 15x9 and under 260$ ea. most any back spacing
    - 15x10 240$ ea. most any back spacing
    - 15x12 280$ ea. 2 pc. Insert, limited back spacing for this rim
    - 15x14 295$ ea. 2 pc. Insert, extra insert material, limited back spacing for this rim
    - 15x14-18 420$ ea. 2 pc. Insert, extra insert material, one half of wheel widened
    [SIZE=+1]16" Rims[/SIZE] - 16x9 and under 290$ ea. most any back spacing
    - 16x10 270$ ea. most any back spacing
    - 16x12 315$ ea. 2 pc. Insert, limited back spacing for this rim
    - 16x12-16 365$ ea. 2 pc. Insert, extra insert material, limited back spacing for this rim
    - 16x14-18 490$ ea. 2 pc. Insert, extra insert material, one half of wheel widened
    [SIZE=+1]16.5" Rims[/SIZE] - 16.5x anything narrower than 9.75" 280$ ea. most any back spacing
    - 16.5x10 260$ ea. most any back spacing
    - 16.5x12 305$ ea. 2 pc. Insert, most any back spacing
    - 16.5x14 355$ ea. 2 pc. Insert, extra insert material, limited back spacing for this rim
    - 16.5x14-18 480$ ea. 2 pc. Insert, extra insert material, one half of wheel widened
    [SIZE=+1]17" Rims[/SIZE] - 17x anything narrower than 9" 290$ ea. most any back spacing
    - 17x9 270$ ea. most any back spacing
    - 17x10 320$ ea. limited back spacing for this rim
    - 17x12-14 345$ ea. 2 pc. Insert, extra insert material, limited back spacing for this rim
    - 17x12-18 470$ ea. 2 pc. Insert, extra insert material, one half of wheel widened
    [SIZE=+1]20" Rims[/SIZE] Light weight 20's
    - Under 9" wide 370$ - 20x9 350$ ea.
    - 20x10-14 420$ ea, Limited back spacing for this rim, 2 pc. insert
    - Other widths available, call for a quote
    Medium duty shells
    - 20x10 390$ ea. most any back spacing
    - 20x12 405$ ea. most any back spacing
    - 20x14 415$ ea. most any back spacing
    - 20x16 550$ ea. most any back spacing for this rim
    - 20x18 560$ ea. limited back spacing for this rim
    - 20x20 575$ ea. limited back spacing for this rim
    - 20x20-30 call for price
    Heavy duty shells
    - This rim is very heavy and is made of used semi rims recentered to your specs. This should be used in very heavy vehicles
    - best for use with military tires 46" and taller
    - 20x9-11 335$ ea. most any back spacing
    [SIZE=+1]22" Rims[/SIZE] 22"rims are now available in and width and back spacing, call for price and availability
    [SIZE=+1]Dually Rims[/SIZE] We are perfection our own method of building very cool dually rims in a 2 pc. design that can be run with or without beadlock inserts, call for price and availability
    [SIZE=+1]Rock rings[/SIZE] All welds are ground and sanded smooth with low spots filled with weld for one piece look
    Rock rings can be added to any order at any time till the day the finish is put on the rims
    Rock rings can also be purchased by them selves and installed by the customer at a 15$ discount off the listed price
    - 15" rims 55$ installed
    - 16" rims 60$ installed
    -16.5" rims 60$ installed
    - 17" rims 65$ installed
    - 20" rims 70$ installed
    - 22" rims 80$ installed
    [SIZE=+1]Pressed Centers[/SIZE] the prices listed below are the upgrade cost for pressed centers in new double beadlock wheels
    Pressed centers are mandatory in 20" and 22" rims therefore the cost of the pressed centers is included in the listed rim cost
    - 15-16.5" rim 25$ ea.
    - 17" rim 30$ ea.
    - 20" rim 35$ ea.
    - 22" rim 50$ ea.
    [SIZE=+1]Cold Roll Rings[/SIZE] 1/2" cold Rolled reinforcement rings welded in place of rock rings
    Cold Roll Rings offer close to the same strength as a rock ring but greatly improve the ability to clean debris for the wheels
    INSTALLED PRICES
    - 15" rims 28$ ea.
    - 16-16.5" rims 30$ ea.
    - 17" rims 33$ ea.
    - 20" rims 38$ ea.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    oh i was refering to the other stuff they sell. such as the doubler kits, and such. my bad
