looking for stock height aftermarket springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Aug 5, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    hey,
    I wanna put my on-road k5 back to stock height. I don't know what kind springs are on the back, but they look stock height (with blocks) but they have teflon pads and are tapered.
    OK, I wanna find a set of after market springs for the front that will ride better then the stock springs. does anybody have any idea where I can get something like this???
    <font color=blue> Jeff - may the force be with you</font color=blue>
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I believe all the springs are no longer avail from GM. Try your local spring shop. They will be able to give you the spring rates for what the can get. A wrecked 91 or so in a yard might also give you some decent springs. I would advise against JC whitney type springs.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  3. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    superlift makes soft ride 1.5" lift springs..........
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, edelbrock performer intake+carb, MSD pro billet http://communities.msn.com/68K10
  4. kmbonomo
    kmbonomo 1/2 ton status
    Jun 12, 2000
    115
    Traverse City Michigan
    Just post it here and in the parts and tires section that you want some stock springs, I did it a couple months ago and had a ton of responses, your going to just remove the blocks in the rear but you need new u bolts, then replace front springs and stearing arm as well as shocks all around, but post what your looking for, theres everybody going higher and just a couple of us going lower so plenty of parts out there...
    Go topless or don't go at all !!!
    83K5 Full Convertible Conversion
    <a target="_blank" href=http://coloradok5.com/readers/reader257.jpg>http://coloradok5.com/readers/reader257.jpg</a>
  5. kmbonomo
    Jun 12, 2000
    115
    PS I put the stock 2 leaf front springs on and they ride great...
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You can get everything you need here:<a target="_blank" href=http://www.espo.com/>http://www.espo.com/</a>
    Their prices aren't too bad. But shipping may cost a bit.
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    <blockquote><font class="small">In reply to:</font><hr>
    You can get everything you need here:http://www.espo.com/
    <hr></blockquote>
    OK, now let me ask you a questions, are these stock springs, or are these better quality springs at stock height??? (man I'm assuming they make their own springs and they ride better)
  8. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Hey man. Check out rough country. I think they make stock height springs.
  9. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Call em and find out. They have a 800 #. All I know abuot these guys is a buddy of mine bought rear springs for his K-20 pu from them and he liked them ok. They were a stock replacement leaf spring. He said they shipped pretty fast too.
    Also as said in an eariler post. Maby check into a local spring shop. They are usually listed in the phone book under springs.
    I had a spring shop in Reno Nv called Johns spring shop make me a Stock set to my own specifications. Check out blacksmith or ornimantal iron shops many of them do springs also.
    I see by your profile you are in Wy. Here is a # for a spring shop in salt lake city I have delt with. They should be able to help you: A A A Spring Specialist Inc
    995 W 2900 S SALT LAKE CITY UT 84119-2435
    PH (800) 282-7439
    Hope this helps.
  10. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I saved everything when I installed my 4" lift. Let me know if you want to talk about it.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  11. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    PH (800) 282-7439
    Hope this helps.
    <hr></blockquote>
    hey thanks for the info I'll have to give them a call.
  12. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    <hr></blockquote>
    right now I'm trying to find a stock height spring that has teflon pads etc. to enhance the ride a bit.
    if I don't find what I'm looking for then I'll drop ya a PM and try to work out a deal.
  13. Cavalry
    Oct 1, 2000
    978
    If you find the springs you want but they dont have teflon. Any spring shop can put the teflon strips in. Its pretty cheap to get done.
    Luke
    84 K5
  14. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    <hr></blockquote>
    hey that is good to know!
    that might be an option. I'll have to give that spring shop a call that was recommended in SLC.
