looking for that website that has the custom hubs.....
Discussion in 'The Garage' started by jjlaughner, Jun 20, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm wanting to put in the 14boltFF but need to stay at 6lug. Seems like someone awhile back posted a link to a place that does custom hubs. I'm wanting a hub that 6lug for a 14bolt and then use a 6lug rotor and backing plate for disk brakes /forums/images/graemlins/thinking.gif
    sound crazy /forums/images/graemlins/confused.gif
    Anyone have a link to that site /forums/images/graemlins/ears.gif
    Or I'll just scrap the whole idea and buy the adapters to stay at 6lug and gain some rear axle width also. Would like to move to a disk brake setup though and I dont really want adapters on the DD, but what the he!!. /forums/images/graemlins/1zhelp.gif
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Those hubs cost like $600 a pair. /forums/images/graemlins/yikes.gif A set of 8-lug wheels is WAY cheaper than that!
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why stay 6 lug? What have you got to lose? All you're running is ralley wheels anyway.
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Actually you can get the full 6lug hub with disk brake setup (no ebrake) for (starting at) $450.
    [​IMG] /forums/images/graemlins/thinking.gif
    On the DD I had never planned going 8 lug, dont want to mess with the swap on the front, dont want to mess with the extra work to pull the tires off (more lug nuts /forums/images/graemlins/tongue.gif), buying new 8lug rims right now is out of the question, esp since I just got 35x12.5x15 MTR's put on my stock rallies, and all the parts I have collected for my 8lug 10bolt swap are going on my project truck. If I done the swap I'd find all the parts again (more money, plus the 8lug rims) and have to do grinding and all that stuff then I couldn't go to alloy wheels I'd be stuck with steelies in the future until I bumped up to a 16" (planning on some 15x8 mickey thompson classic locks next spring) and then I dont want to have an $800 set of tires sitting in the garage and have to buy new to fit 16" rims. /forums/images/graemlins/dunno.gif /forums/images/graemlins/tongue.gif
    I'm just looking into other options /forums/images/graemlins/deal.gif
    why go the same-old same-old route, when something else will fit my needs better /forums/images/graemlins/dunno.gif
    It would be like ordering a set of 5" lift springs because 4" aren't enough, then I would have a set of 4" lift springs sitting in the garage and casue myself alot more work than tossing in a set zerorates to gain the inch I want /forums/images/graemlins/deal.gif
    Why buy all the front 8lug parts, do the swap, buy 8lug rims and be stuck with 15" steelies, when I could easily do the 14bolt hub swap AND gain disk brakes probley for not much more than the new 8lug parts and new rims then still be stuck with drum brakes on the 14bolt /forums/images/graemlins/thinking.gif
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Ya know, i went through the same decision making you are trying to finger out, Finally i just said f-it, and did the 8 lug conversion, actually i found a pretty good deal on a 3/4 ton front axle at a junk yard with 4.10's in it, so i grabbed it, the reason i went 14bff on the rear was i broke the original 10 housing, not the carrier, but the actual housing, just bought me some stock 6.5 wide steelies, and will be buying new wheels in the next month or two.
    I personally feel after doing the swap, i made the right decision.
    BTW TonyP makes some adapters from 8 to 6 lug, that was another option i was considering.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Reason I see, 15" aluminum rims. Only real reasons I could see for going 6 lug.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The 14FF hub is too big for stock 6-lug rally wheels.
    The 6-lug spacer/adapter and 6-lug conversion only work on aftermarket (or stock import) wheels that have the larger center hole. Even still, the hubs and axles need to be turned down a little bit.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    do you have the 14bff already for the DD? if not just get a 14bsf 6 lug out of a 88 and newer light duty 3/4 ton truck, youll have to move the spring pads, but its 3" wider than the rear axle in your truck /forums/images/graemlins/waytogo.gif
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yeah basically, just have to go pick it up...
