loose column shifter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pismorat, Mar 19, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    When I am going up a steep dune or hill in 4wd, if I have the tranny(TH350) in Drive, it tends to slip into Nuetral, if I have it in Second, it goes into Drive. What could the reason for this be? I recently re-built my tranny(for other reasons), and it had done this before, so it must be something else. Any suggestions? /forums/images/graemlins/truck.gif
  2. dyeager535
    26,975
    Any chance the column is loose and with you holding on while being shaken around, the lever is moving? I know the lever gets loose when the column loosens up, or at least tends to.
    Is the shift linkage hitting anything in the engine bay or underneath when the engine torques or the frame twists?
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bet you just need to adjust the shift linkage. It might be almost between gears and when you hit a bump (or the motor moves because of the torque) it changes gears.
