Loose Hub???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Truckfan2, Sep 20, 2000.
  1. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    Just this past weekend I was home and noticed that my right Warn Premium hub was loose (I could move the whole body of it up and down & side to side) It wasn't terrible but I'm worried 'cause it used to be a pain in the butt to engage but now it's much easier... any ideas? Should I pop it off and check the retaining rings?
    Have been stuck (once) as of 8/12/00
    "(2H) Where's all the mud?.(4H)...(4L)..(4H)... oh crap"
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Try tightening the bolts first, if you haven't already.
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Mine are the same way. Don't overtighten the bolts on the hubs, they can be a bear to get back out. You're prb. gonna leak a little fluid out around the hub so keep an eye on your diff fluid level. Mine are like that because the frontend is in need of a rebuild and there's a lot of slop in the front axles, seals, and bearings. I'm not overly concearned with mine, I just keep an eye on things for now, I'm planning a swap soon.
    Kyle
    89K5
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    If you really have diff. fluid in your hub area you got real problems.
    You better do that swap now !
    Good luck
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    dude, ive never seen diff fluid in a front hub before...
    i hope you haven't either.
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  6. Kyle89K5
    2,273
    OKLAHOMA
    mine was leaking out around the axleshaft U-joints. The seals are bad. Mine didn't get loose till the seals finally started to go in the housing. Guess they were the last thing holding it even a little snug. The bearings and seals at the spindle. I've tightened the hub and rotor(not the locking hub) as tight as I can (or dare) and still have slop. I have movement in the whole axle not to mention that the splines on the axle are a little gone. Guess my wording starts to suck when it's early and I'm trying to type as fast as I talk. Sorry about the confusion. My bad.
    BTW, I don't have the dual seal setup on my dual frontend with dual locking hubs (right executioner [​IMG])
    Kyle
    89K5
  7. shaggyk5
    1,610
    SE pennsylvania
    oh man, not you too....
    shaggyk5
  8. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    If its the bolts/screws holding the hubs on use some loctight blue on the threads. That kept them tight on my j### and To****. I'm now K5 and full sized and starting to build.
  9. Kyle89K5
    2,273
    OKLAHOMA
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Kyle
    89K5
