Loose Lugs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ziagong, Jun 12, 2000.
  1. ziagong
    ziagong Registered Member
    Apr 5, 2000
    19
    CA
    My front Lugs keep looseing on there own, what causes this scarry phenomenon?
    1972 K5 CST Blazer - 350V8 17x40x15
    Made for Mud!
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    If you don't use a criss cross tightening patteren they can come lose. Also tourque to specs.
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    If that doesn't work, how about green or blue Loctite? Is that a bad idea? The only Loctite I've used is the hardcore red stuff.
    '73 K5
    Chevy good...Ford bad
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    If the back of your rims have rust on them, smal flakes could be working off causing what you describe.
    Dont use lock-tite.
    <font color=blue>Espen88k5 at: </font color=blue>http://espen.coloradok5.com
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yes Espen is right, take a wire wheel and clean the back side of each wheel and rotor to make double sure there ain't nothin inbetween!! May want to get some new nuts as well!?
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I second the new nuts. Also, I overtighten them, i know some say it is not good, but it is better then having you nuts come loose and the tire fly off!
    Actually I am known for over tightning everything and breaking bolts. I have broken many wheel studs! :) ooppss!
    Mike
    1982 GMC Jimmy - Emmett
    http://emmett.coloradok5.com
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's part of your problem: 17x40x15
    Those monster tires are exerting WAY more force on the lugs (and spindles and bearings, etc) than they were designed to handle.
    Find out the proper torque specs and use a torque wrench to be sure you are tightening them properly. Over-torqueing can stretch the bolts to the point that they no longer have any elasticity. Without that the bolt loses it's ability to hold a load properly. (It's the reason most engine builders will replace rather than reuse head bolts. Proper torque is critical to that application).
    http://ThunderTruck.ColoradoK5.com
  8. ziagong
    Apr 5, 2000
    19
    CA
    Harry, I have 35" meats now. It happend on both. I am planning on taking it appart and wire brushing the back & rotor, & replacing the posts & lugs. Thanks for all your help, there in nothing worse than hearing those lugs falling off and feeling the tire wobble free (happend twice now). Luckly the tire stayed on because the hub comes out so far.
    Made for Mud!
  9. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    I had a similar problem after I got my new centerlines. Seems the shop used generic type nuts, normally I wouldn't think twice about that. But my wife blew all 6 off the right front! Tire didn't come off either!. Anyway switched to Gorilla Brand & they've never come loose again!
    Rick
    86 K-5
    http://www.BigBadBowTie.ColoradoK5.com
