Loose shock mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mastiff, Jul 16, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    On the rear passenger side of my K5, the shock is attached to the frame at the top by a mount thing that is screwed through a hole in the frame. I assume it's similar on everyone's? The particular mount hardware I have now came with my RS5000 shocks.
    Anyway, the mount thing that attaches to the frame always comes loose. I tighten it as much as I can, and within a month it's totally loose again. When it's loose, I can push on the rear bumper and hear it rattling/creaking.
    Any suggestions for how to deal with this? /forums/images/graemlins/confused.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Weld it! /forums/images/graemlins/thumb.gif
    85K5 3/4ton 14bff/10b,9" lift,16.5x14 welds,big horse 406SBC/700r4
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    If you should decide to weld it be carefull, the fuel lines run inside the frame rails right by the shock mount. Have you tried to put some thread lock on it or locking washers?
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Lock nuts......
  5. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    aircraft locknutsand locktight
  6. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    purposely cross thread the bolt /forums/images/graemlins/smile.gif just kidding. Yes welding be really careful. blue thread lock would be a good choice or nylock nuts.
  7. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Well, both rear mounts were loose. I had no lock washers, but the nuts themselves were those nasty oval shaped self-locking ones. Anyway, I went and got some grade 8 washers and locknuts (the old washers kept getting bent out of shape). I think I've got it torqued down pretty well. We'll see how it goes...
    Loose shocks make quite a racket. /forums/images/graemlins/tongue.gif
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    A follow up here. Turns out the source of the repeated loosening (and mysterious noise) is the fact that my shock was limiting my travel on the rear driver's side. It took me a while to figure this out, but when I jacked up the frame until the tire came off the ground, it was pretty obvious.
    I thought to check this out when it finally struck me that the shock mount was angled down. I'm kinda peeved that Rancho sold me a lift "kit" with shocks too short for the rear lift. /forums/images/graemlins/angryfire.gif
    Now I need to get some better shocks that are softer AND don't hit when the suspension droops. It kinda sucks that I can't trust the manufacturer charts for shock application though.
  9. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    It's actually a GM engineered problem....You will find lots of rants about this.
    It is sad that they fawked up like they did and the only way around fixing it is either throw on limiting straps or redesigning the shock mounts so you can use the whole shock, none of this losing 3 inches of droop cause the shocks are too short.
  10. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    It looks like the shocks I have on there have a range of 16" to 26.25". I was only about an inch from full droop with the shock maxed out. I can get a DT8368 that goes 17" to 29.5" and have a few inches to spare. I'm not sure if the shock would limit the stuff on the short side, but I've got some huge poly bumpstops that must be at least 2" longer than stock. It seems like that should protect me. And I don't plan on getting airborne anyway...
    Now I need to figure out what to do with the front duals. I think they are limiting me too. If I only attach one, should it be the inner one or the outer one? I like the outer (front) one because it's longer, but I'd also prefer to mount the shock inside the shock mount on the axle side, not outside it with a super long bolt.
  11. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I'm using Gabriel #G63438 shocks in the rear. $20. They're around 27" long fully extended. So far I haven't had any problems.
    That's the longest one I could find made by Gabriel that had the ends we need. They do make one that is 29" long but one end is different than the other.
