Loose steering question..78 K5,33x12.5s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Neil, Aug 2, 2001.
  1. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    '78, 33x12.5 tires. otherwise stock. What can I do to see why my steering is so loose? I have to really over steer to correct sideways travel down the road. Are my steering gears loose or are the tires doing it or something? Power steering,Auto trans,4x4...Thanks.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  2. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    My 77 does the same thing, I have to hold the wheel about 30 degrees to the left to keep it going strait. If I let go it starts it starts to pull to the right.
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <font color=white>http://community.webshots.com/user/jonathandwill</font color=white>
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Sounds like you both need to check for worn steering componets, and get to an alignment shop.
    Keep it simple!
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Check drag link adjusment and ends.
  5. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    I'll have steering stuff checked out for good measure..Also&gt;&gt;.do large tires ever get flat spots if they sit up not driven for 2 or 3 days? seems like it is a little bumpy until the tires warm up a little. Thanks for info.
  6. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    I replaced my steering stabilizer and that solved most of my steering problems. I had to correct left and right and left and right to keep my truck going straight. I had 10 degrees of play in the steering. If you haven't already, try a new stabilizer.
    '73 Blazer, 4" lift, 33" BFG Muds
  7. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    How much are they$$ usually and where can I get one? Could I install it at home or need pro to do it??
  8. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    Are the front suspension/steering pieces on the 4x4 trucks the same????Sorry if this sounds dumb, but I have found some differences when trying to interchange parts before between 4x4 GM trucks and my 4x4 K5.
  9. dyeager535
    26,979
    I can narrow some of the steering stuff down for you, I hope. If your vehicle tracks straight, but the steering wheel is off center, your drag link is not "centered". If you get more response turning the wheel one way than the other, then you may have worn drag link ends (balljoints I believe they have on them) If your truck consistently pulls to one side when you let off the wheel, you need an alignment.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Changing your steering stabilizer didn't solve a thing, it just hides the real problems better.
    Tim
