Loose steering
Discussion in 'The Garage' started by bamf, Aug 28, 2005.
  1. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    Fayetteville North carolina
    Just bought a 87 k5 blazer. It has 35' tires on it with a lift kit, not sure how big the lift kit it looks to be like 4' or so. anyways I have never owned anything bigger then 33' tires. So my question is are the tires making the Steering loose on this truck or is there a problem? and If so what should i be looking at
    thanks
    Alan
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I'm going with some sort of problem, check everthing from the tie rod ends to ball joints all the way up te steering linkage to the column..... also check the frame where the steering box bolts in to see if it is cracked or if te bolts are loose
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    check your wheel bearings, too.
  4. bobalob
    bobalob 1/2 ton status
    Jul 20, 2005
    157
    Everson, Washington
    my loose steering turned out to be caused by splines stripped off sector shaft by pitman arm that started gradually slipping over about a month until undrivable
