Loose steering
Discussion in 'The Garage' started by Dafey, Apr 8, 2007.
  1. Dafey
    Dafey 1/2 ton status
    Feb 10, 2007
    2,675
    Roswell NM
    How do I tighten up the steering?It has around a 1/4 or more turn of slop in it.:confused:
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Look for anything worn in the sterring system and make sure the box is not coming loose from the frame.
  3. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    Well I looked today an found several loose parts.I should have looked before asking...
  4. THISISWEIRD
    THISISWEIRD 1/2 ton status
    Mar 10, 2007
    165
    WV
    What did you find loose? Just curious as I've been dealing with my own steering issues.
    Mine doesn't seem to be tight either, but I've replaced the steering box and tried to tighten up everything I can find.
  5. BlazerBud
    BlazerBud 1/2 ton status
    Jun 14, 2006
    473
    Chattanooga
    My steering is tight, but my steering column is all loose. 76 Blazer. I think it's from all the white knuckle wheeling putting stress on it. The joint that is for the tilt steering seems to be real sloppy, has anyone else fixed something like this? Just curious before I tear it all apart to look at it, I don't want to break it worse.
  6. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,543
    1,457
    the armpit of the east coast, 08046
    there's a good thread on here with step by step. i started to do mine last week and finally gave up. it was easier to go to the junk yard and find one thats tight and just swap it in.
  7. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    Well every thing but the ball joints are worn out.The PO didnt keep them greased.:mad: So thats just more of the $20-$50 things I have to replace...
  8. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
  9. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    if it makes you feel any better, i think i may have to swap my tie rods, idler arm and maybe wheel bearings on my 94 c1500. i keep the stuff greased up, but for some reason i developed a lot of slop, patricularly in the left side, a few weeks ago. i know a few of the grease fittings are cracked and broken, so that blows.
