loose steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by the hulk, Dec 25, 2003.
  1. the hulk
    the hulk Registered Member
    Feb 9, 2003
    phx az
    is there anyway to take the play out of the steering box I heard that you can tighten a nut on the box to take some of the play out it . I don’t have a lot but with the 36'S on it want to wonder a litter web page
  2. tRustyK5
    Jul 23, 2000
    E-town baby!
    With so many other reasons for sloppy steering I'd leave the steering box adjustments until very last.
    Check the box bolts first...mine have come loose a few times
    Tie rod ends...could be worn
    Drag link ends...same
    Rag joint...could also be worn
    Ball joints
    cracks in fame where the box bolts up
    With a frame repair kit, repaired cracks, a bolt on brace, new drag link ends, good tie rod ends and everything tight I have no play in my steering at all...and that's running 39.5's and a single stabilizer.
    The best is to get someone to slowly move the steering wheel back and forth while you watch every component from underneath. Worn parts make themselves known quickly. Cracks in the frame and loose steering box bolts often cause a clunk as the box deflects under stress.
  3. BadDog
    Feb 24, 2001
    Phoenix, AZ
    I just did the "watch while someone cranks the wheel" test a several days ago on the K5. Found out that the output shaft is wobbling a little contributing to steering looseness. Probably a shot bearing I'm guessing. But as Rene said, don't adjust the box unless it needs it, make sure everything else is tight first. Then have someone move the wheel small amounts, just enough to see the input shaft move. You should also see the pitman arm moving. If you can move the input without the pitman moving, it may need tightening but look at everything else first.
