Loose U Joints, worn yokes?
Discussion in 'The Garage' started by fwc, Nov 20, 2006.
  1. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    So the U Joints caps on my rear driveshaft are loose in the yoke, this is with new U joints. They are so loose enough that I can just slide the caps into the yoke, no need to press them in. Yes, they are the correct part number and yes I have vibration. Stock 10 bolt with stock driveshaft on a 91. Is my driveshaft wasted?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yep time for a new shaft.
  3. goldwing2000
    goldwing2000 Guest
    Just weld 'em in place. :crazy: :haha:
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah you could get away with just replacing the yoke if you had to. probably be 20 bucks or so for a new yoke, another 40 to have it welded on. no biggie unless the rest of the shaft is as toast as that yoke.
