loose wire
Discussion in 'The Garage' started by dragon66, Apr 15, 2003.
  1. dragon66
    dragon66 Registered Member
    Mar 4, 2003
    27
    Denver, CO
    I have found a green wire hanging down by the starter that I noticed after wheeling. Can't find any possible connections from the transmission or starter. Any ideas? Still runs fine.
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    If you are actually wooried about it, then trace it back. It will probly go through the fire wall. I have one that sits on my engine right behind the AC compressor. There is already a wire hooked up to it and the truck runs fine. AC don't work but I don't care about that. I don't worry about it. Just trace it backwards and see where it connects.
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Nuetral safety maybe? Can you start the truck in gear? I'd say the same, trace it back as far as you can...
    Bee32, did you know what that wire was? Sounds like your AC compressor clutch switch power. Disconnecting it wouldn't affect the engine, but the ac clutch wouldn't know it was supposed to be engaged when you turn the AC on...
  4. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    Yeah check that. Also see if it reaches the Transfer case. If it does than put the truck in 4x and see if your light comes on. Could be that. I would say check the safety switch and then just trace it.
    As for mine. I never even concidered it. I seen a wire connected to the compressor and didn't ever look at it again unless I am cleanin in there and it gets in my way I move it over. I am from Texas and I grew up drivin a motorcycle and a 73 Luv so I never got used to havin AC. Unless we are in my wife's truck than I roll down the window and go faster to cool off. 2/60 AC works enough for me. /forums/images/graemlins/thumb.gif
  5. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Hey David I know All the blazer's that I have owned
    have a few extra wires here and there. But I would look
    at the 4x4 switch for the light. If you need some help with your Blazer let me know I live in Englewood.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    does your temp gauge work? my temp gauge wire is green, and if it was loose, might hand that low, its on the drivers side though, but things changed over the years.
  7. dragon66
    Mar 4, 2003
    27
    Denver, CO
    I had thought about the transfer case and it looks like something was missing but wasn't sure on the right side. The light doesn't come on when I shift into 4 wheel. So I will check that out. As for the ac, I am not too worried about that, like everyone else, the windows roll down and if worst comes to worst the top comes off. If anyone has any other thoughts let me know. I definitely appreciate the feedback. /forums/images/graemlins/ears.gif
