loss of power
Discussion in '1982-Present GM Diesel' started by 6.2er, Mar 29, 2002.
  1. 6.2er
    6.2er Newbie
    Mar 27, 2002
    3
    wa usa
    question you guys i have a loss of power at higher Rs
    it mostly happens at about 75 on the hiway. i have an 85 blazerwith 6.2 and a 700r. have any toughts.
    thanks mike
  2. fender
    fender Registered Member
    Aug 18, 2001
    92
    port moody b.c.
    I don't think the 6.2L was designed to do 75, but I could be wrong
  3. chevyuser
    chevyuser Registered Member
    Mar 27, 2002
    15
    Ingolstadt ( Home of AUDI), Germany
    Here in Germany we are allowed to drive a little bit faster as you know and i always drive about 65 to 75 Mph on highways.I don´t think it can´t stand that speed.A good friend of ma and René always speeds up to 90 miles on highways.His CUCV is equipped with a hughe oil cooler for its tranny and i think one too for its engine...
    Perhaps the Transmission oil cooler is a little bit too big because last time he went home from a meeting, the distance was about 250 miles and the tranny temp was only 20 degrees(C).And that with an average speed of about 90 miles!!!!
    Ok enough of the stories...
    @ 6.2er:
    Perhaps your tranny isn´t working correct and is slipping at higher speed.Unfortunately, your Blazer has to speed up to about 110 Mph!
    My CUCV has real good power at 65 to 75 Mph.But i don´t know if we have the same axles and so on.As i know the CUCV has the more powerful engine in it. Perhaps you shouldn´t accelerate in OD.
    Which tire size is mounted on your truck?I found that mounting 33-12.5 R 15 and bigger brakes the power significantly(?grammatically correct?).If you want to overhaul, it needs very much time with big tires and original axles...
    Ok so far from me, have a nice day over there
    Greetings from the easterbunny....
  4. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    You write you have a blazer with TH700. I think it is an “C”-engine, but also your blazer would have to go 90 mph.
    There would be two things to clear:
    Does the engine get enough air (air cleaner clogs)?
    Does the engine get enough fuel (fuel filter clogged, lines leaking, broken, or the pump does not operate correctly)?
    If you have a concrete suspicion, we can help you surely.
  5. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I've had my blazer over 85 MPH several times, and it wasn't going downhill. It will happily cruise at 80, getting 16 MPG. Not bad for a truck with 37" tires at 5000 ft altitude. My engine is all stock, right down to the EGR manifold.
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Mine will also go over 80, half the time I dont relize im going that fast till I look down.
