Loss of Power
Discussion in 'The Garage' started by MontanaLifted, Sep 4, 2002.
  1. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    Can a worn out torque converter cause a power loss?
    You know, steal power from the engine?
    I have heard that water sometimes finds it's way into the torque converter and that can tear it up, true?
    Go with it...
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    If the torque converter is worn, it will probably slip. A lot of slip will reduce power at the wheels. The torque converter is always filled with trans fluid. If your transfluid is water, then water is in your torque converter.
  3. MontanaLifted
    Aug 27, 2002
    171
    Hahaha
    Thanks. Maybe I should use tranny fluid in my radiator. (inside joke from another post)
