Lost cruise control first, now wipers every once and while
Discussion in '1992-Present Chevy & GMC models' started by crahm, Jan 23, 2003.
  1. crahm
    crahm Registered Member
    Jun 19, 2001
    41
    Dallas, Texas
    99 suburban: Lost cruise control first so I checked around for leaky vacuum hoses and didn't find any. Now, when I turn on the wipers (same control stalk), they sometimes turn on and sometimes don't. I saw other posts about checking the circuit board for the wiper motor but I thought I'd ask if the control stalk is ever a problem?
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The wires in your control stalk are probably messed up...you can get a new one at NAPA. Before you install it, lup it into the plud under the dash and see if the cruise and wipers now work. If they do, then run the wires through the column. Its kind of a PITA...make sure you use string to pull the wires though and not dental floss like my dumbass tried to do
  3. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    i second 90k5's diagnosis
  4. crahm
    Jun 19, 2001
    41
    Dallas, Texas
    Thanks for the replies. I'll call NAPA and order a new stalk.
    How do you remove the cover off the steering column? Or are you leaving the mechanical stalk, but replacing the tip with the switches?
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    you push the stalk in and turn it to get it out
  6. Sparty
    Sparty Registered Member
    Aug 16, 2002
    13
    Grand Rapids, MI
    alright, i had this same thing happen to me. if you have the column that turns to turn on off and to relay this can fix yours too.
    -my wipers quit and i talked to a guy who explained that the gap created when you turn the column is letting in dirt and dust everytime you use your wipers. i realize that the gap is minimal but inside the gap is 2 pieces of metal that conduct the electricity to run your wipers. those pieces are now dirty. he told me to go to a local electronics shop and buy a aersol can of tuner cleaner ($10.00). i did and brought it back to him. he put a jack knife in the gap and spread it open, then sprayed the excess away. turn the truck on and the wipers work.
    - i carry a knife everyday and the tuner cleaner now rides behind the seat in a sock. in about 3 months i have only needed to do it one more time after the first time.
    - to fix it permantently you would need a new column which i am told is very costly. it was cheap and now its been months and i havent had to touch it again
  7. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    WOW i must try this as my Cruise control has not worked in forever and i like cruise control!! and my wipers have a mind of its own like when i only want it to go one time it does it for like 4 to when ever it stops and no matter how many times you switch it to off it still wont stop. SO i must try this can of air and a knife. Now do i spray it in the upper and lower gap or what? btw thanks for this cheap trick fix. /forums/images/graemlins/deal.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I had this exact problem with the wipers, they would not turn off and the spray would not work or anything. I had to open up the wiper motor box and resolder about 5 connections that had broken loose on the circuit board. Now the thing works like it was brand new. My cruise does not work either. Maybe I'll try the cleaner trick on it.
