lost front brakes...help!
Discussion in 'The Garage' started by MUD JUNKIE, Jan 9, 2005.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    I lost my front brakes today out at a rock quarry. I was all twisted up on a pile of rocks. I think the cab twisted to much since theres a body lift.I poped off the stock hard bakeline for the front brakes at the master cylinder. I cut the line where it broke off the bolt and tred to retaper it.it worked and does not leak as a trail side fix,then I bleed the brakes and still nothing no pedal. should I cut and retaper it with the correct tools to start there,or did I pinch a line somewhere else? it has 4 wheel disc brakes if it helps to know.
    http://img.photobucket.com/albums/v236/Mohitojj/DSC00160.jpg
    this is where I busted it:D
