lost headlights tonight
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Kodiak, Oct 9, 2001.
  1. Kodiak
    Kodiak 1/2 ton status
    Mar 17, 2000
    178
    Kodiak Island, Alaska (the emerald isle)
    I was driving down the road doing 60 and hit a bump. Out went the lights. The park lights still work but the headlights don't work and the bright light indicator in the dash didn't work.
    Where should I look for the problem. How can I tell if it is the light switch?
    Also, the wiring is awful. Almost every wire has been spliced at least once. How hard is it to replace the wiring?
    <a target="_blank" href=http://kodiak.coloradok5.com>kodiak.coloradok5.com</a>
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    CHECK under the hood i bet its the ground wirethat gos to them
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    A good starting point is the dimmer switch after you check the ground wires for the light. The dimmer switch is a poor forgotten soul that is responsible for all kinds of light problems.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)<P ID="edit"><FONT class="small">Edited by chevyracing on 10/12/01 10:23 AM.</FONT></P>
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I agree with Chevyracing: Dimmer switch. All of the power to the lights from the headlight switch goes through the dimmer switch. Another indication that it's the dimmer switch is that the high beam indicator is also not working. It could be something as simple as a loose connection to the dimmer switch.
  5. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    Also check the wiring harness on your high beam floor switch for corrosion. If your windshield frame is leaking, water will run down the inside of the A-pillar and drip onto the floor by the switch. My switch shorted, killing the headlights.
  6. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    That dimmer switch can do all kinds of things. If I run my high beams very long the lights go out because the switch is shot and overheats due to the exact thing you said, my windshield leaks on it. I need to replace it again, this time I will use new and not used.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
