lost my high lift handle....
Discussion in 'The Garage' started by down4thakrown, Oct 9, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    anybody know where i can get another one with out buyin a new high lift?? i also need that piece that bolts to the top used for clamping and winching. :doah:
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    chunk of pipe prolly work.
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    yea, that could work, :doah:
  4. bridgeguy
    bridgeguy Registered Member
    Mar 8, 2002
    90
    Oroville, Kalifornia
    Found this at Summit Racing. Click Here
    It's $14.69 or something like that. I wouldn't use a pipe, personally, as you're talking about a cast iron product (read that as brittle) vs. a carbon steel. The pipe most likely will not warn you before you snap it and it is not designed to be loaded in flexure.
    Just my $.02.
  5. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
  6. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    A peice of pipe will be fine. Anything that you will probaly come up with will more than likley be thicker and stronger that the wimpy one that comes with it.
