Lost my Keys far from Home!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bennett, Jan 3, 2001.
  1. bennett
    bennett Registered Member
    Nov 12, 2000
    45
    My son lost the keys to the 90 Jimmy ! He is away at school, I had a hide a key but he had used that long ago. Can I get him a new key by using the Vin# , are Key codes available for a 90 and can the dealer cut a new key from cod?.......need a little advice here. Thanks and hurry!
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only key codes I've ever seen on a GM come as part of the key itself when brand new. The numbers are on the part that gets knocked out so the key will fit on a key ring. Without those, it may be a little tricky to get a key made without the services of a good locksmith. Take his bill out of your sons party money, for not replacing the spare after he lost the first key. [​IMG]
  3. dyeager535
    26,980
    Your other option, if you have the door key, is pull the lock cylinder out of the ignition (not that hard) and take it to a locksmith. Under $30 they can make you a new key for it. Gives you or your son an excuse to: A) tighten up the loose tilt column, B) buy a lock plate compressor ($10 at auto supply store) or C) all of the above : )
    Dorian
    Dorian
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  4. angelglo
    angelglo 1/2 ton status
    Aug 4, 2000
    105
    S.F. bay area
    i dont know what year they started doing it but the dealer can cut a key by pulling the vin. also cheak with a lock smith. they can rekey the ignigtion without changing the switch. it will be an original key as if you just got it duplicated. i had it done on my 69 camaro for $75.00 for home service.
    <P ID="edit"><FONT SIZE=-1>Edited by angelglo on 01/03/01 01:51 PM (server time).</FONT></P>
  5. dyeager535
    26,980
    Wonder how that works? Want to steal a car, just call in the VIN, pick up the keys, drive it away? Must be something more than that, but i have heard the same, you can call GM and ask them. I'm sure you have a local dealer.
    Dorian
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Maybe you have to show your title/proof of insurance and a ID
  7. northgate
    northgate Registered Member
    Sep 29, 2000
    75
    Sisters, Oregon
    Can you get in the vehicle? If so, remove the passenger door lock; it has the key code for the doors. You will best off in getting a new ignition lock from any automotive parts store, but you'll need a steering lock plate removal tool to access the cylinder. Good luck
