Lost my only set of keys.......
Discussion in 'The Garage' started by stallion85, Jan 11, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have an 86 K5 I sold my bud. I lost my keys the other night and it had the only set of keys for his K5 on it!!:doah:
    What are my options? Any of you guys have a ball park to have a locksmith cut keys for the door and ignition?
    Man my stomach hurts!
    I have never lost a set of keys before.......go figure it happens at the worst possible time:mad:
  2. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    i went down to the dealership and got one made for 5 bucks....just have to have all your information, vin number, all that crap........ but then again this was on a 93 truck not an 86. but its worth a shot if you havnt tried that already.
  3. jayweb
    jayweb 1/2 ton status
    Jul 6, 2003
    213
    NC
    a dealership can only look up key codes on a 90 or up - a locksmith is probably your only option. here in north carolina I got hit for 96.00 to unlock my 2000 tahoe. I'm sure being in vegas will be higher.
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Id imagine that you could find a set of door locks and i know you can get a new ignitionfor about $25. I know its a PITA but might be cheaper to just buy all new lock cylinders and install them yourself. Its a real PITA to pull apart the steering column but its cheaper than paying $100+ for a locksmith to cut u a key or whatever.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The lock cylinders have their code stamped into them. If you take the cylinders to a dealer, they can cut you a key.
  6. goldwing2000
    goldwing2000 Guest
    Buddy of mine bought an '89 Blaze from a police auction with no keys at all. I think it cost him $135 to have the ignition and both door locks replaced by a locksmith.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    How about taking the locks off your 85 , and just paying for the ignition key form a locksmith . You can find other locks at your leisure , since you don't run doors anyway . If you still have your doors .
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Ya, I tossed the doors a while back :doah:
    I might get a steering wheel puller (I need one anyways), pull the cylinder and have a new key cut. Then I will have to find some door locks, man I a cussin myself right now!
  9. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    tube doors.
    j
  10. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i had a shop replace my ignition for i think $35, but it was just a back home shop out in the woods .
  11. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Another option.....
    Get a couple of blanks for the ignition. Get a pair of vise-grips. Get a couple of files. Put the grips on the key in the ignition and turn it. Pull it out and look for marks on the blank. File the marks down. Repeat. It doesn't have to be perfect, to work. I have seen blanks open doors before on older models.
  12. dyeager535
    26,979
    And lots of GM ignitions when worn will accept other GM vehicle ignition keys if they are close. :)
  13. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    It should be a "A" code key (as long as it hasn't been CHanged before)... Try some freinds keys to see if anything works.
  14. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    Yep. my blazer key works on my buddys Siearra
  15. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    My 77's ignition key is identical to my 80's ignition key, lol
  16. absolute
    absolute Registered Member
    Apr 7, 2005
    77
    Near Spokane, WA
    i replace the entire tumbler in my 88 F-250 for $35 myself, picked up a new one at Napa and pulled the steering wheel, took about a hour. I never had to do that with the K5 b/c its worn and i never lock it.
  17. 70chevybob
    70chevybob Registered Member
    Apr 25, 2004
    28
    Ada,Oklahoma
    My Father-in-law is a locksmith here in OK and the way he dose it is he gets your vin# and cross refrenceses it with the code book and cuts a key. He Cut mey 3 keys for my 70c10, and 86blaz in less than 10 min. He said that He charges about 5$ a key and it costs him aobut 2 cents for a key blank. If the Door and the Ignition are different he can make them match again for about 5 dollars more. That is how most locksmiths work. Prices may Verry
  18. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    A keyless push button.
