Lost of Power
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hafa213, Feb 20, 2001.
  1. hafa213
    hafa213 Registered Member
    Feb 11, 2001
    5
    Need help!! I have a 350 small block with headers.replaced gasket with the copper one's and they leak pretty bad. would this cause lost of power. or could it be somthing else. I replaced spark plug wires,spark plug,cap and rotor.need your help!!!
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    If you hear what sounds like an exhaust leak near the block or down at the collector, then yes. Did it happen first thing right after you put on the headers? What brand headers are they?
    [​IMG] Keep your feet dry [​IMG]
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the power's way down, then double check that you installed the plug wires correctly. It only takes 2 wires installed to the wrong plugs to make a V8 really run like crap!
  4. hafa213
    Feb 11, 2001
    5
    yes,right after i installed the copper gasket sounds to be a the block. so i returned it to GI joe's and replace it with Mr. gasket. it seems to be a lot better. still have a little noise. but a better improvment.i think i should replace my wires to silicone wire. i might have a broken one somwhere what do you think.
  5. dyeager535
    26,975
    Throwing money at something that may or may not be the problem gets expensive : ) Start the truck, and pull each plug wire off individually. If pulling the wire affects the idle of the truck, the wire is good. If pulling the wire does NOT affect idle, the wire, plug or cap is bad. JUST went through this on my truck. BTW, If you EVER have a loose terminal on the cap, replace it. That terminal is what keeps the rotor contact piece inline, and if its loose, the rotor WILL eventually hit it and bend it out of the way, causing no spark on that terminal.
    Dorian
  6. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    make sure the collector gaskets are good too. it's real easy to warp the headers. you might also have warped heads. I've heard some people putting double gaskets on their headers, but i've never done it
