Lost rear brakes.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Jan 28, 2003.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I recently went this weekend on trails that have lots of mud and water. When I got back, I pulled the drums to get all the mud out. When I got it back together, the rear brakes started squeaking alot when braking, and pulling to the left really bad. I pulled them apart again, thinking I hadn't cleaned them out good enough, so recleaned them with brake cleaner. Put everything back together. Now when you spin the drivers rear tires in the air, you can hear the rear drivers side rubbing against something, its not constant though. I have no rear brakes now, can't even get them to lock up. I do have a firm pedal though. The rear shoes are new. Any ideas on what I screwed up? /forums/images/graemlins/confused.gif
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Are the wheel cylinders working at all? IE, do you have pressure at the rear brake lines? Did you crush, break a line? Do you have the enuf fluid in the res?
    Just my .02...
    -Dan
  3. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    OK, the rear brakes came back and seem to be working, but the still pull extrememly bad to the left. /forums/images/graemlins/crazy.gif
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Check the right rear drum for contamination... usually if it pulls, check the opposite side for problems. /forums/images/graemlins/wink.gif You could still have some crud in there, or the shoes have been hosed, and may need to be replaced... /forums/images/graemlins/blush.gif
    -Dan
  5. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    you shouldnt put any cleaner on the shoes
  6. Grim-Reaper
    7,385
    Atlanta
    Did you take the auto adjuster appart and clean it? Then tighten them up till they slightly drag the drum? The adjusters tend to jam when they get in the mud. Also check the front caliper slide pins and make shure they are not full of crud and moving freely.
