Lots of carbon in cylinders??
Discussion in 'The Garage' started by S10K5, Jan 29, 2005.
  1. S10K5
    S10K5 Registered Member
    Jan 10, 2005
    10
    Phoenix, AZ
    I bought this TBI 350 out of a '95 Tahoe to drop in my project. Owner said it was running when it was pulled (truck was wrecked). I figured I would inspect it before I dropped in in just for good measure. There are large amounts of carbon deposits on all of the piston heads and the valves. Also on the #2 cylinder there is a small amount of surface rust twards the top of the stroke.
    My question is what could have caused the carbon build up in the cylinders, and what should I do about the rust?
    Any info would be great!
  2. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    Carbon build up can be caused by a number of things, engine running too rich, blowby, weak spark/no spark, leaking/cracked valve seals, etc, etc...., as far as the rust on the cylinder wall??? goes I would think honing it should clean it off.
    If you want to remove carbon without tearing into the engine you can use GM combustion chamber cleaner.
  3. S10K5
    Jan 10, 2005
    10
    Phoenix, AZ
    Can I get that at my local auto parts store or do I have to get it from the dealership? Also is that something I would use prior to assymbly or is it a fule additive type of product?
    Thanks again for the help.
  4. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    Top clean is a dealer item.
    You can also buy Seafoam in a can. Find a vacuum hose and rev the motor up while you let the hose suck seafoam out of the can. This will make a lot of smoke out of your exhaust.
    Seafoam is found mostly at small auto shops, and i do believe nappa carries it.
  5. James670X
    Nov 15, 2002
    122
    You can buy the GM combustion chamber stuff at any of your local auto parts stores or any GM dealership (at least you can up here in Canada anyways).
    A person could use it one of two ways, either spray it down the throttle body or carb or you could soak your pistons, valves, etc.... and use it that way as well.
