lots of chev parts/more added
Discussion in 'General Parts for Sale' started by 74 chev, Sep 30, 2004.
  1. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    Brake proportioning valve $10
    3 inch raised steering arm $10
    1.5 inch sway bar drop brackets $10
    Alternator $15
    Flex fan $5
    Four rancho six inch lift shocks $25
    600CFM Carter carbuerator $50
    Starter $10
    Power steering pump 1973 $25
    73 chev throttle cable $15
    TH350 flex plate $20
    1973 chev instrument cluster $25
    GM 12 bolt Brake drum in good shape $10
    stock TH350 tourqe converter $20
    76cc sb 350 heads need to be rebuilt $50
    1 inch add-a-leafs for a 73-87 chev $25
    1/2 ton 5/8ths thread u-bolts 13.5 inches long for a 5.5 inch lift block $20
    1/2 ton rear spring plates $10
    1/2 ton front spring plates $10
    4.09 gears for a dana 44 in great shape $30
    14 bolt FF 3.73 gears in great shape $25
    14 bolt FF axle shafts $25 each
    14 bolt FF hubs $50
    front driveline for 74 chev with 203 t-case all new u-joints and a new cv-joint $30
    1973 chevy truck complete wiring harness in great shape $50
    1973 master cylinder $10
    1973 brake booster $10
    1973 sb350 stock valve covers $10
    4 Eagle Alloy 1430 series aluminum rims 16.5x9.75 in great shape with hev 6 lug pattern $350
    4 38x15.50x16.5 SSR Radial super swampers 75% with no damage at all $900
    Extended rear driveline for 8 to 10 inch susp lift with brand new tube and u joints and a new slip yoke. it came off of a long bed chev with 9 inches of lift and sm465/203 $75
  2. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    Re: lots of chev parts
    I'll take that conversion ujoint, pm'd ya
  3. 74 chev
    Sep 30, 2004
    159
    Concord,CA
    TTT
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    You selling the VIN and title for that 73 also?
    Eric M.
  5. grundy99
    grundy99 1/2 ton status
    Sep 13, 2004
    389
    Loveland, CO
    Sent you a PM
  6. 74 chev
    Sep 30, 2004
    159
    Concord,CA
    no i already got rid of the title and vin.
  7. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    wow, you're in longview... my fiance is from longview and still works there. small world! anyway, i may be interested in your ff14b shafts. How are the splines? any rust or other damage?
    j
  8. 74 chev
    Sep 30, 2004
    159
    Concord,CA
    nope no rust and the splines are in great shape.
  9. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    PM sent about the carb...
  10. capps
    capps Registered Member
    Feb 6, 2004
    40
    Atlanta (Snellville)
    Do you still have the sway bar drop brackets? I have an 84 3/4 ton that I put a 4" lift on,
  11. jck54x4
    jck54x4 1/2 ton status
    Aug 18, 2004
    104
    Houston, Texas
    Is it a stock alternator?:D
