Lots of parts in AZ need money help
Discussion in 'General Parts for Sale' started by DesertDueler, Jul 2, 2003.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I have lots of parts that I need to sell asap. No job still and need cash. All parts are or best offer plus shipping.
    -12 bolt axle 30 spline in great shape $50 obo
    -87 TBI heads 60,000 miles on them, needs valve seals includes seals with heads $150 obo
    -86 dash unit with gauges, bezel etc. cut out for cd player and has 1 small crack in clear plastic non tach setup $150
    -glovebox- grey w lock mechanism but no key $20 obo
    - c.c. bracket/ t.v. cable bracket off an 86 $20 obo
    -(2) stock 5 blade fans no fan clutchs $10 each obo
    -P/S pump and bracket assembly off an 86 good pump $50 obo
    -A/C box, inside and out w/ heater evap, and control panel and wiring $150 obo
    -86 GMC steering wheel w/ horn button $30 obo
    -10 bolt thick front cover $15 obo
    -RH tailight 73-87(91) $5
    -IAC motor for 454 TBI (4 pin connector) $10 obo
    - 3.73 gears for dana 44 great shape $25 obo
    - dana 44 spiders, side gears and pin for 30 spline $25 obo
    -Ford 390 FE heads with 30,000 miles 200 obo
    -(2) flowmaster 2 chambers 2.25 *SOLD*
    -(4) 15x8 Eagle 589s 6 lug 3 3/8 bs $275 obo
    Built SBC No miles
    355 (.030) 350 with 350+ hp. 10.5:1 compression, chevy pink rods with ARP bolts, forged pistons, roller rockers, roller timing chain, performer RPM intake, chrome valve covers and water neck, HEI dist, autolite racing plugs, ported heads and good valves, harmonic balancer, and road race oil pan that was extened to hold 6 quarts. Ready to bolt in just put a carb on it. $2,200 obo LOWER PRICE $1,700
    Munci 4 speed trans with no miles
    Came out of an 85 vette, 4 speed munci, just rebuilt. HD internals, stock gear ratios inside. Includes bellhousing, clutch assembly with throwout bearing and pilot bearing, and flywheel(just turned) *sale pending*
    Thanks for anybodys help, my bills are starting to pile up and need to part with some stuff.
    Dan
    /forums/images/graemlins/k5.gif
  2. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    how much thicker than stock is the 10 bolt cover? i might be interested.
    rick
  4. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I am interested in the 4 + 3. You said it was a Muncie. Is this tranny the Doug Nash version?
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The cover is the factory stock thick one.
    Dan
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    do you have a complete TBI set up?
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Sorry tony I dont. I have a ECM, dist., and a wiring harness. You would need to get a throttle body, and a fuel pump.
    Dan
  8. TONYP
    Aug 13, 2002
    2,116
    so cal
    I'm checking around to see what is needed to complete the system, I might of found the throttle body...what else would I need...O2 senser, temp?
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Just the sensors(o2, coolant temp, and knock). I think I even have a coil I can throw in for you.
    Dan
  10. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i have no idea what the thickness is on the regular cover and the thick one. the one i have is a little less than 1/4" thick. is yours thicker than this?
    rick
  11. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    That is the same one I have.
    Dan
  12. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    thanks anyways. hopefully someone else will pick it up from you.
    rick
  13. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
