loud clank .. when shifting .. etc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, May 26, 2005.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    i finally have my truck on the road ... been years .. she has 14 bolt,w/detroit and sm465/205 twin-stick .. hydraulic clutch ..d60 crossover/arb ..
    i am driving this thing to costa rica in july .. and need to get her where i feel comfortable ...
    have a couple of things going on ..
    1) when shifting i feel a clank 80 % of the time in between shifts or when i let off the gas it sometimes will mak a similar noise ... it sounds like it is coming from the t-case and tranny area
    2) at high speeds when getting on it .. there is a rattle sound coming from the tranny .. sounds like a bearing going or something ??
    3) sometimes the detroit will give out a huge BaNG when driving ...
    4) when disengaging the clutch sometimes the truck shakes pretty bad when letting off ... could this me a master cyl ??
    is this normal ?? anyone experience any of this before ??
    thanks for the feedback ...
  2. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    Have you checked the u-joints?
    gabe
  3. bigblue
    Dec 6, 2000
    658
    southern california
    the ujoints are pretty new ..
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I'll take a shot but there just suggestions...
    1) (since the u-joints should be ok) the 465/205 combo has a lot of inherent slop so if it's a clunk when going between power and coast I would bet it's normal backlash (I'm also assuming it's not violent like something is loose).
    2) Driveshaft vibration? New lift?
    3) Sounds like normal Detroit function. They can make sounds and/or jolts when locking back up, this typically is more noticable with manual trannys.
    4) Definitely not the m/c. Is this going straight or usually when turning? Can you better describe the shake? Where do you feel it (seat/steering wheel/whole truck/etc).
  5. bigblue
    Dec 6, 2000
    658
    southern california
    don't think it is driveline .. my axle perches were cut and welded and right now the pinion in pointing straight at the t-case ..
    as far as the shaking .. it seems like it is when the clutch is being released .. and pushing up onto the pressure plate .. ???
    the whole truck rattles pretty bad ...
    thanks ...
  6. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    When my old truck had a 4spd and Detroit and it had some peculiar characteristics (like the loud bang when it engaged).
    When I used to turn, clutch and coast into my driveway I would get a lot of audible "clunking" along with a mild shudder during a turn as the Detroit tried to differentiate. The shudder was sort of a feeling like the truck (Detroit) was fighting the tight turn.
  7. bigblue
    Dec 6, 2000
    658
    southern california
    this is good to hear .. as i am used to the 700r4 and 208 combo ..
    the one thing that irks me is the shaking when letting loose of the clutch ..
    all of the clutch components are new .. and for whatever reason is still does it ..
    one thing to note is that much of the clanking when engaging the clutch happened after i put it into 4wheeldrive for the first time ... makes me wonder if for some reason the t-case is having a problem .. i have the twin stick from ORD ... i know that the front driveshaft isn't turning .. so it shouldnt be engaged in 4 wheel drive ...
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    What kind of driveshaft are you running in the rear? If not a CV style, then the angles at the tcase and rear axle should be the same, or you will prematurely wear out u-joints - and cause this type of noise....been there, done that!
  9. bigblue
    Dec 6, 2000
    658
    southern california
    yep, got the cv style ....
  10. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    are all of your mounts intact.. tranny,engine ? just a thought ( I ripped all of mine in half in one weekend..eg dont buy the cheap napa ones )
    gabe
  11. bigblue
    Dec 6, 2000
    658
    southern california
    yes .. the tranny and engine mounts are brand new and look perfect ...
    the clutch seems to be settling down a bit .. but there still is a clank in between shifts ..
  12. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    did you have the flywheel surfaced when you did the clutch
    gabe
  13. bigblue
    Dec 6, 2000
    658
    southern california
    negative .. could this one of the problems ??
  14. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    Sometimes When A Clutch Is Replaced And The Flywheel Is Not Resurfaced You Will Get A "chatter" It Feels Like There Is A Shake In The Clutch Pedal When Released And The Whole Truck Will Shake Like You Let The Clutch Out Too Quickly With Not Enough Throttle.
    Gabe
  15. mr_blasto
    mr_blasto 1/2 ton status
    Nov 8, 2004
    495
    Irvine, CA
    Sorry I can't help you at all with your problems, but I have to mention how green with envy I am about taking a k5 down to Costa Rica. I was just there in March driving a rental jeep around. A few years back we got into some sticky situations trying to wheel a rental KIA. The whole time I was down there I was planning in my head an epic adventure consisting of my k5, 1-4 people, some surfboards, and thousands of miles of coastline. I am so jealous that you are actually doing what seems to be a similar trip. Be sure to report back with the details! Good Luck!
  16. bigblue
    Dec 6, 2000
    658
    southern california
    oh, yeah ..
    it is going to be an amazing adventure ..
    you need to read "in search of captain zero" ... book that describes the whole drive down to costa surfing and camping ..
    i have an offroad pop up camper w/35 inch tires on it .. will be dragin that puppy everywhere ...
    i will post up some pics when i can ...
    pura vida
