loud clank
Discussion in 'The Garage' started by bigrollin76, Feb 28, 2005.
  1. bigrollin76
    bigrollin76 Registered Member
    Feb 15, 2005
    26
    phoenix
    ive get a loud clank when i shift into reverse or drive it sounds like its coming from my drive shaft of rear end. thx
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Ok. lol. Whats yer ?
  3. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    Lay under the truck and rotate the driveshaft by hand. Listen/look for the clank location.
  4. Calvin313
    Calvin313 Registered Member
    Jan 17, 2003
    6
    Collierville, TN
    might be the u joint. I'd check that one out.
  5. AkMudr
    Dec 30, 2004
    917
    Alaska
    Throw it in neutral and also rotate the dirveshaft at the back of the tcase, check for excessive play. Not sure what kind of truck it is though. Sounds like a ujoint.
  6. bigrollin76
    Feb 15, 2005
    26
    phoenix
    1976 k5 350/350/203 14bff. it almost sounds like it might be between the u joint and or the gears.:dunno: :k5:
  7. AkMudr
    Dec 30, 2004
    917
    Alaska
    Might be safe to just change out yer ujoints, Ive had them be completely tight, no play but make noise and be totally screwed. Check yer pinion nut, I have seen those come loose and make make noise
  8. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I have a clunk too, but have replaced all u-joints, I think its in my t-case, possibly the chain.
  9. AkMudr
    Dec 30, 2004
    917
    Alaska
    ^ Probly..My '85 has does it since Ive owned it.
