loud grinding sound when going up a hill
Discussion in 'The Garage' started by adamforsythe, Nov 23, 2004.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    When my truck starts to go up a hill I will hear this loud grinding sound coming from under the truck. What is going on??? Plus my truck keeps on kicking out of gear. And the only way to get it back into gear is to put in "N" shut the truck off and then stick it in 4L then I will start the truck put it in drive and the take it out of 4L.
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Is your transfer case slipping out of gear? How well is the transfer case linkage adjusted?
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Ye my T-case is slipping out. I don't know how well it is adjusted. How do I check without taking it to the shop? I need my tranny and T-case to last in tell I get a NP205 and my new custom built TH350 tranny.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Tranfercase could be shot already . I put up with that for a long time before it wouldn't grab any gear except 4 low . When it starts popping out and grinding on the street at 45-50 mph you'll really be annoyed . By the time I tore the case down the range selector was so worn I couldn't put the plastic pads back on , as the whole thing was knife edged . There really isn't much else to go wrong in there . Adjust the linkage , if it persists , you'll need to rebuild it or replace it /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    When I am going down the road at 55 and I start to stop and turn the truck will kick out of gear.
    Adam
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Doesn't soound good then . Adjust the linkage first for kicks and grins , but I have a feeling it isn't going to do anything in your case , sooner or later you won't be able to put it back into gear , or into the gear you need . I lucked out and got it to grab 4 lo , and I wasn't far from home with highway gears so I could do 30 /forums/images/graemlins/frown.gif
  7. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Might be a loose or broken mount or crossmember letting the t-case move enough to make it pop out of gear--or a cracked adaptor or tranny case--whatever it is,it doesent sound like an easy fix...good luck.. /forums/images/graemlins/crazy.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Before you do anything else, check your fluid level.
