loud hum noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, Jan 12, 2003.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    ok this is what i got, when i drive my 87 k5 and i reach range of speeds of 45-55 a loud hum starts close to the back of the truck. i have changed the u-joints for the rear drive shafts, i opened the rear end to see if the axle was empty of oil and replaced oil. so if anyone has any idea what this could be please let me know thanks
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    What kind of tires you got??? has it always done this?
  3. K5Psycho
    Jan 6, 2002
    55
    FL, USA
    i have 33' x12.50 A/Ts when i let go of the gas the hums goes away and i hear the tires hum
    yes it has done this since i got it
  4. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    i to replaced my rear shaft and joints and still i have a hummimg vibe outback /forums/images/graemlins/angryfire.gif.. i'am thinking its got to be the bearings in the 14ff.. it only does it under load and noticeable above 1800 in 4th..(sm465)
    i took the rear cover off and all looks well but bearings are very finnicky.. so maybe you could start there.. good luck /forums/images/graemlins/grin.gif
  5. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    Are you running stock 10 bolts? It could be the preload on the r&p on maybe the spiders.
  6. K5Psycho
    Jan 6, 2002
    55
    FL, USA
    yes stock 10bolt with 373 gears and posi trac
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    i vote bad bearings on the pinion...Mine does the same thing and the gears are really starting to wear a groove into one another.....if you have a hum it only gets worse trust me! FIx it or swap out axles...Mine is to the point of scary right now... /forums/images/graemlins/crazy.gif
  8. K5Psycho
    Jan 6, 2002
    55
    FL, USA
    OK I AM GOING TO TRY TO CHANGE THAT THIS WEEKEND ANYONE ELSE KNOW ANYTHING PELASE POST
  9. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    Ring and pinion. Try replacing the bearing first jus because its cheaper. While your in there check the wear pattrern on the gears. If the edges are sharp you have a problem. If not you don't have to worry to much about it if the bearings dont quiet things down. If the the noise continues check the "Purple" post for a type of fluid that might help.
  10. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    My vote is the carrier bearings. That is my problem.
    BowTie, mine is not to the point of being scary just yet, but bad enough that I am not driving it the 150 miles to get my 14 bolt this weekend.
