Loud snap, crackle, and pop coming from the rear end
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91gmcjimmyCH_IL, Mar 7, 2002.
  1. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    When I start from a stop there is a loud niose coming from the rear end that is like a cracking niose. This has been going on for a long time but now it is really bad. I had a friend try to see where the niose weas coming from only to have him tell me that the pinion on the rear is moving up about 2 inches and then coming back down. What is causing this to happen? I would bet that it is because I didn't put the pinion yoke on right and screwed something up. Any input would be appreciated.
    The rear is a 10b with a gov lock.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When I blew my govlock in my rearend, it would make loud pops as I went around corner. That might be the source of your problems. Beyond that I can't help you. Sorry.
  3. blzr83
    blzr83 Registered Member
    May 11, 2000
    72
    eugene OR
    you probably lost your pinion bearings....if you didn't preload the pinion with the crush sleeve correctly that could cause the pinion to move freely as it pushes against the ring gear during acceleration.
  4. 91gmcjimmyCH_IL
    May 24, 2001
    110
    Grayslake, IL
    The movement I'm talking about is that the whole axle pitches up. the pinion moves up about 2 inches to give you an idea of how bad it is.
  5. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    Have you looked at your rear leaf springs(bushings) When I fried my 10 bolt I broke a spider gear inside and the piece of metal got bound up between the ring-pinion which locked up the rear but the axle never pitched upwards like you are describing it happened all at once while I was on a back road doing 15 mph (thank god) but my problem was all internal. your best bet would be to pop off the cover and look inside for broken teeth and metal shavings take a magnet and tape it to a screwdriver and push it into the pumpkin to see if any loose metal comes out.If all looks well the check all of the leaf springs and bushings and u-bolts for breaks or looseness sometimes when the axle is loose and moving around the leafs it will make strange noises ....hope this helps good luck........
  6. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Pull the diff cover and let the rice crispies out...
    j/k Couldn't resist, hehe.
  7. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    how do does your spring pack and u bolts look? its not just the pinion that is moving, its the whole axle...right? sounds like something has comeloose in the susupension to me. any broken leaves?
