LOUD sqweel from a/c comp. i think...anybody had this happen???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 01maroonz71, Jan 26, 2007.
  1. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    well, my a/c blows cold on my 83 K10...but when the compressor is on...it sqweels really loudly when i give it gas(ie. driving around) but at idle it doesn't do this at all....could this be the belt is bad or would it be something internal in the compressor/clutch??? also....this is the belt that goes from the fan to the compressor to the PS pump...so it runs 3things....anybody got a clue????
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    belt is too loose , even if you think it is tight . You can tell by squirting some silicone or belt drssing on it and watch it go away temporarily .
  3. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    well...i tried the bar of soap trick....didnt work...
    also tried the toothpaste trick(to get rid of glazing) didin't help either...
    i will try silicone...i think im just going to replace the belt and see where im at. thanks a bunch ya'll!!!!
  4. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    well...there is a new problem now...when i turn on the a/c..it smells like something is on fire or burning and the stench fills up the cab quickly...smells like burning rubber...no good.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Does it smell like a burning belt? Replace the belt and tighten it up.
  6. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    10-4...haha...i was hoping thats what it was....ill get er done tomm. i can't wait to go serpentine.
  7. cbbr
    Jul 17, 2004
    14,681
    My OBA belt is doing the same thing. At least its a small PITA.
  8. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Take a close look at the alternator belt. I've seen it lots of times that people think the A/C belt is loose because it only squeals when the A/C is on, but the additional electrical load will make a loose alternator belt squeal...at it will happen at the same times as a A/C belt could squeal.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Probably belt squeal, but could be the compressor starting to lock up.
  10. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    well, i replaced all 3 belts today, since they're so cheap and i had to pull one off just to get the a/c belt off i figured what the hell...and it cured the sqweel...thanks for you help guys!!!! and now i have 3 spares incase one of these gives way!
