loud thump sound coming from rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foreverchevy, Mar 16, 2002.
  1. foreverchevy
    foreverchevy Registered Member
    Mar 3, 2002
    6
    evertime I hit the gas I get this thump....like boom! sound coming from the back of my truck ,also when i'm stopping..what the hell is it? any info will help. thanks.
  2. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    Check your spare tire. Maybe rolling around, just a guess.
  3. Snowbound
    Snowbound Registered Member
    Mar 12, 2002
    52
    Minot N.D.
    Had same problem a couple of years ago. Pinion gear was loose. I could move it around by hand.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Always check universal joints first. If one is shot, you are lucky. If you are not lucky, you have SLOP in your rearend. Make sure that it's not something stupid rolling around in the bed. Also, check wheel bearings......It's sad, but I've actually seen 12 bolt wheel bearing so worn out I could jiggle the axle.
  5. foreverchevy
    Mar 3, 2002
    6
    how do i fix the pinion gear if it's loose...
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> Is it your sub box ? Seriously, Check your u-joints or your pinion.
