Low buck shackle flip
Discussion in 'The Garage' started by 86454K30, Feb 5, 2007.
  1. 86454K30
    86454K30 1/2 ton status Premium Member
    Dec 24, 2004
    669
    40
    Spokane Washington
    I have a question I just bought a cheap 78 3/4ton 4x4. I lined up 35s, 4" front springs. Here's my question, is there any reason I can't trim a window out of my rear spring hangers gusset the top and do a inexpensive shackle flip. I assume there is a reason this won't work or others would be doing it. Just thought I would ask
    thanks
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yes, it will work. Quite a few people on here are running that setup. Search "home brew shackle flip"...it has been covered quite a few times.
    -Harrison
  3. 86454K30
    Dec 24, 2004
    669
    40
    Spokane Washington
    Hey thanks. I been on this site awhile...and just now found the search button. Too busy lookin I guess.
    Thanks again!
  4. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I'm not sure the way your talking about but most people will use the rear spring's front hanger to do their shackle flip on the cheap. THat's what I plan on doing. So you will need to source a shackle hanger off of another truck. Hope this helps.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    There are better "cheap" routes. You can use the front hanger, of the rear spring, off a 2wd to act as the new hanger/shackle flip.
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    This is 85mudblazin's old pic: I believe he still uses the hanger, but not the same shackles.
  7. TheAustrian
    TheAustrian 1/2 ton status
    Jun 20, 2006
    160
    Austria
    how much is the lift with the 2WD rear shackle? I have unfortunately only a 4" all leafs lift kit installed. No I'd like to rise about 2" front and 3" rear. Would simply work with 2" and 3" Blocks, but the shackle flip looks much better.
  8. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    you can vary your lift height by were you mount those. higher on the frame means lower lift.
  9. TheAustrian
    Jun 20, 2006
    160
    Austria
    and to do that I just need a rear hanger of a 2WD Blazer? My shackles will fit just right away?
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    heres my homemade shackle flip. stock 4wd hanger cut out the bottom and then added bracing on top
  11. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    you need a front hanger of a rear spring. from any chevy 1/2 or 3/4 ton truck , 2 of 4wd. just go look at yours, and get another like it.
  12. TheAustrian
    Jun 20, 2006
    160
    Austria
    unfortunately I cannot see your picture, I have not yet subscribed...:blush:
  13. TheAustrian
    Jun 20, 2006
    160
    Austria
    okay, now I got it. Found the front hanger on LMC-Truck. Do you think this hanger will go for 2 or 3 inch of extra lift?
  14. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    depends on how you mount it to the frame.
