low coolant light
Discussion in 'The Garage' started by colbystephens, Apr 24, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    why does my low coolant light come on?
    just kidding. :rolleyes: kind of.
    my low coolant light turns on and off on quite frequently each time i drive my truck, but my coolant is full. on my 6.2, where is the level sensor? what should i be looking for to fix it?
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    It comes on because an electrical current is sent to the bulb behind the dash.
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    oh.
    moderators these days . . . sheesh. :rolleyes: seems they'll just let anyone be one.
    j/k.
    pad.
  4. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Did I sell you a defective gauge unit?
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i ended up just swapping in the guages from the cluster you sold me into the original, umm, i don't know how to refer to it - i swapped the guages into the white guage pod b/c the circuits on the back of the one you sold me was too messed up. it's cool tho - i still saved money buying from you b/c it would have cost me a pretty penny to replace the guages i had broken, plus you got me a tach which i'll find a way to hook up. :wink1:
    any ideas, anyone???
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    by the way, alan, it does this even when it's not attatched to the guage set - just dangling from the wire.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Ah, the joys of electrical gremlins
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I think the coolant level sensor is the single-wire gadget on the right-side radiator tank, below the heater hose fitting. Last time I ran mine, I had enough coolant in the radiator to cover that sensor, but I still got the light intermittently. Probably a grounding issue...
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i bet you're right. i thought that was the sensor. i'll have to take a look.
  10. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    I swapped radiators and don't have a place for that sensor anymore (and I don't need it, so don't care). But the low coolant light stays on all the time. Is there an easy way to trick it, other than sticking the sensor in some coolant? I tried grounding the sensor and grounding the sensor wire, and got no change, light still on.
  11. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Maybe you could ground it through a resistor, or just use a resistor and skip the sensor? No idea what value to try, but maybe somebody can tell you, or else they could tell me I'm wrong.
  12. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Oldest trick in the book.......Remove the bulb:haha:
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    tried that too. ;)
  14. jarheadk5
    Mar 6, 2000
    4,389
    PA
    X2...:D
  15. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    I'll look in the shop manual and see if I can get any clues about that resistance value.
    EDIT: I didn't see anything in there, but I just took a quick look through the book.
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    remove the bulb. :)
    Other than that, I have the same light- issue is, I dont know where the previous PO put the wire, or how the wire is run- I have the sensor, but I don t know how to hook it up.
