Low coolant with no obvious leaks?
Discussion in 'The Garage' started by afroman006, May 15, 2006.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Well my DD crewcab (98 K3500 with 454) has been sporadically overheating and I thought it was a stuck thermostat so today I was going to replace it. I took radiator cap off and saw that it was low on coolant, so obviously thats why it was overheating. I topped it off and it ended up taking a gallon and a half of water. That is alot of damn coolant to leak over a fairly shorty period of time, and I have never noticed any leaks underneath. It does however, have water dripping out of the exhaust. I never thought much of it and kinda figured it was from condensation or something, since the water is clear and my exhaust doesnt "smoke." Could I have a bad head gasket or cracked head?
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    yes. do a compression check.
  3. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    Does it have that orange coolant, GM has had a problem with that eating seals or something to that effect. Probably a head gasket or intake gasket.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    My guess, given the year of the truck would be a head gasket as well. My 97 lost coolant over the coarse of a long period. Not much, but you could see it going down slowly but surely. When I finaly went looking for it, it turned out the be the head gasket. They are pretty common trouble spots for that vintage. I'd have to recommend that you at least give that a good going over in your effort to find the problem.
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    so is this a common thing on all GM engines of this vintage. My 98 malibu has a slow leak that sounds just like that, sorry for the hijack
  6. afroman006
    Aug 21, 2002
    2,876
    SSShhhhhiiiiiittttt. That's gonna be alot of damn work to fix...and expensive too.
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Pressure test the system... Yet another occasion where that tool is invaluable...
  8. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Its not really as big of a problem on the big blocks but Id say intake gasket ?
  9. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    bet ya 5 bucks your malibu is intake gaskets. we do 10 sets at least a month at work. :haha: :haha: :haha:
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    My 87 was doing that and turns out the seal went out on the Water Pump but it was turning to steam so I had no indication of a leak. Just a thought.
    Ira
  11. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I don't know if it's as common on the 454 or not. I do know that it is not if, but when, on the 98 & 97 350's though. Everyone I know who has one they bought new, has changed it... some sooner than others. I was told it was a bad batch, or poorly designed gasket, and also have heard that the dex-cool is partialy to blame. I don't know about the dex-cool, everyone has their own opinons about that, but I have been told by several mechanics that the gaskets are poorly designed. The new gaskets are better. Mines been done a while now with no coolant loss at all. Same results with everyone I know who replaced the gaskets.
  12. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    better yet, Leakdown test.
  13. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    You could check your oil level, to see if it's unusually full (because of coolant leaking into the crankcase).
  14. afroman006
    Aug 21, 2002
    2,876
    Nothing unusual as far as the oil goes. I'll do a compression test and see what it says.
  15. redneck396
    redneck396 Registered Member
    May 17, 2006
    10
    Riverton, WY
    I would pressure test the radiator also.
  16. redneck396
    May 17, 2006
    10
    Riverton, WY
    Also on the under side of the waterpump is a weep hole. usually you can snake your arm in there and wipe a finger across it. If it comes back wet you need a new water pump. if you decide to do the compression test take a careful look at your plugs. they will be wet and possibly have a white powder residue around the edge.
  17. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    another test...
    I second the pressure test..also,many shops here use the exhaust gas "sniffer" used for emission inspections to detect bad head gaskets or cracked heads and blocks...they run the engine with the radiator cap off,and hold the probe just abouve the coolant..it will detect even slight traces of exhaust hydrocarbons..
    I've had a few motors with no detectable external leaks,but they used a pint or more of coolant every few weeks..I suspected cracks in the heads between the valves,having seen many that way at work--such a slow,minute leak,it goes right out the exhaust-- it does not contaminate the oil...I added a tube of "Aluma-Seal" stop leak powder,and rarely had to add any coolant after that..might be worth a shot..but it wont work for long,if at all,on a head gasket leak,no stop leak will,regardless of what the package says..:crazy:
  18. peter redman
    peter redman Registered Member
    Dec 28, 2002
    11
    duncan,b.c.
    at work i had a 89 chevy van with a 305 that had the same problem.the driver really overheated the motor to the point that the mechanic who was looking at it said the van needed a new motor.work decided that the van wasn't worth it and gave it to me.when i fired it up it ,it went thru 10 gallons of water at idle due to the blown head gasket.i then headed off to lordco and picked up a bottle of irontight block seal.my buddy who was followig me had turn on his windsheild wipers on a warm summer day because of the water loss.2 miles later the smoke stopped and drove the sun of a gun 40 miles home with no problems.i later vsold the van and 3 weeks ago spoke to the new owner and he has had no problems since and he has put 30k on it.another way to quickly check if the head gasket is gone is to remove the rad cap ,start the motor with a full rad and see if the rad water is bubbly and or frothy.if so blown head gasket.
