low end power question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Jan 18, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    i notice this alot when in OD...
    from about 1000rpm to 1500rpm, if i stomp the gas...it wants to loaf, hesitate, call it what you will, til it gets up to about 1700-2000 then it starts taking off.
    Im wondering if my truck has a problem, something with the carb mabye? Or is this normal.
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    does it downshift?
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Does it do the same thing in "D" ???
  4. tecton
    Dec 1, 2002
    1,553
    WV
    yeah, the gear or speed doesnt matter so much, ist just im usually more likely to be driving down the road at that rpm while in od...but its at any gear, any speed just that rpm range...the downshift wont happen til it climbs up in rpms
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I would look into the TV cable adjustment....
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm far from a carb guru, but it sounds to me like you have a problem with your secondaries opening properly.
    Maybe someone who actually knows about this will post up. /forums/images/graemlins/rotfl.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sounds like you're slow on timing or your advance weights are stuck.
    Could also be a vacuum issue with your secondaries as well, as mentioned above.
    Every Q jet I've ever driven had a mild bog as the secondaries opened though.
  8. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Yeah, carb secondaries or timing.
